Question about Whirlpool ACQ128 Air Conditioner
I have an old window air conditioner still in use.( model AC1352xt).Is it suppose to shut off when the room has cooled? I dont have the user manuel to refer to. Can you help? Thanks
  • Gladys Steen May 23, 2011
    The air conditioner is at least 20 years old. Thanks for your reply and your advice.
    Mrs.Steen
    Yes,I had considered the age of this product. Tought maybe I could get a copy of the user manuel.
  • 670 Answers
all airconditioners should have a thermostat. Most models/unit's turns off once the temperature set in the thermostat is reached. Hpw old is your air conditioner?
If its not shutting off when the set temperature is reached there might be a problem with the thermostat reader and a service would be needed. If it's quite old a new one might be better as new air conditioners are more environment friendly and economical.
Posted on May 23, 2011
  • Marlon Deza
    Marlon Deza May 23, 2011
    no problem, however if it's been that old a user manual might be impossible to find or we would have to really look for all the four corners of the internet. If it's 20 years old I think it served its purpose and really would have to rest. :)
Haier a/c model esa408k-l mode is set on cool, speed set on high temp is 81 held temp button down, goes to 61 with in seconds goes back to 81.
Free Haier Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Haier
Products 1 - 50 of 548 - Haier Split Type Room Air Conditioner Operation Manual. Pages: 0 Saves: 0 ... Haier Room Air Conditioner Installation Manual. Pages: 0
Aug 26, 2015 | Haier Heating & Cooling
I have Royal Sovereign ARP-1000ES Portable Air Conditioner. Last a few days, it shut off When running with cool mode.(no problem with dehumidify or fan mode) I checked water tank, but it's empty. Please...
It is supposed to shut off when the room meets the temperature you set it for. Are you saying it shuts off before the room cools to the temp you set it for?
What do you mean "..last a few days...?" Is it new only a few days and then break?
Be clearer if you need help.
Oct 18, 2013 | Heating & Cooling
Kenmore window air conditioner model 580. Blows air but nott cool air. wont cool the room.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 02, 2011 | Kenmore 76129 Air Conditioner
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
I own a Zenith Air Conditioner, model ZW651OR. It is only a month old and it is not blowing cool air any more. I live in Guam (relatively a hot climate) the size of my room is 10' X 12' and the air...
The problem could be dirty filters, dirty coil, refrigerant charge low,etc. Since it is only a month old I would try to return it if possible.
Aug 25, 2010 | Heating & Cooling
How to stop a leak
the water leak is not a big concern -other than the mess it causes, but as to the AC's operational status it is supposed to draw water/humidity from the 'cooling space' so - it's still doing it's job (I'm assuming it's cooling too).
As to the water - I would check the drain to be sure it's not clogged up - which is usually the problem. If the drain is clear and the AC is draining (to the outside) properly - I would then check and make sure the AC is tilted backwards out the window.
good luck!
Jul 13, 2010 | Carrier BCA101R Air Conditioner
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Aug 02, 2009 | Heating & Cooling
Re: air cond. should exhaust lever be open or closed to cool off?
Im not sure what type of unit you are speaking about but in general a window airconditioner unit will have an exhaust button. This button generally opens a small door that allows a small ammount of fresh air to mix with the conditioned air from the room. When it is closed all of the air is recycled from the room. To cool a room fastest, close the outside air inlet.
Jun 21, 2009 | Heating & Cooling
Trying to set air conditioner
it shouldnt run for that long if it is sized right for the room in the first place. Does it not come back on after it runs for 30 to 40 mins?
sounds as though it is not the correct size for the room to me
Jun 30, 2008 | Goldstar KG6000R Window Air Conditioner
Whirlpool ACQ128 Air Conditioner Logo
173 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
