Question about Plumbing
My second SM-303-BS has failed now. Each lasted no longer than 2 years. I have the pump on a timer which powers the unit from 7am-9pm. On both units the propeller has seized in the housing, but will operate once I take it out and manually get it started with a pin of my hand. Also, i clean the housing of any build up with emery cloth, but unit still wont spin in place. Thanks for your time! PG
  • 258 Answers
Replace it with a Taco 006 bronze recirc pump, and y
ou will not have this problem.
Posted on Sep 14, 2017
  • 409 Answers
SOURCE: Kitchenaid KAWS750JQ3 Top Load Washer
hi there,
make sure that the program is not on the "Intermittent Agitate Program". that would be the cause of the delay.
the other issue would be the timer itself. the timer is mechanical, so once the contact on it is corroded, it will only function intermitently or not at all.
please let me know if i can be of more help.
Posted on Sep 28, 2008
  • 659 Answers
SOURCE: Unit will not operate
Find your manual and check the code of the blinking green light. It will give you the resolution for your code. If you still have issues, post a comment back on this thread and I will be able to help you. You will need your model number for the website.
Posted on Mar 21, 2009
  • 9 Answers
SOURCE: Flotec water pump.
Sounds like water hammer when water stops flowing abruptly it will "hammer" in the pipe the solution is to have a bounce tube above your faucet this gives the water a place to lose energy.
Posted on Sep 08, 2009
SOURCE: Pressure switch operates every 2/3 hours
Faulty switch I think? This is typical of one... Or the controller spiking
Posted on Mar 15, 2010
SOURCE: We have a sanipump 2 macerator that seems to work
sanipump 2 periodicaly operates without pressing the flush what is the problem or possible causes
Posted on Oct 06, 2010
Outdoor light transformer
Depends on Brand. Some have 5 year warranty (Intermatic) while most have 1 year warranty
And how you maintain unit.
And if you get power surge etc
Copy following link for tips keeping power pack lasting longer:
Add a comment
Jul 01, 2013 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Where can I buy timer pins?
1) Copy following link for Intermatic replacement trippers, and tips for longer lasting power pack, 5-year warranty, and troubleshoot.
2) If this is not your timer, Add comment Feb 2013 and describe timer in detail.
Feb 07, 2013 | Malibu ML200RT - Low Voltage Power Pack...
How can i have my samsung turn on at 7am
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Sep 27, 2012 | Cell Phones
Timers usually don't last more than a few years, unless you buy the heavier duty box timers that last decades.
Dec 20, 2011 | Hardware & Accessories
I have a Simply Perfect For The Home brand Microwave Oven that I bought from the U.S. Military post here in Schweinfurt, Germany for $50 I live on the economy in my own apartment. The microwave is a 120...
Just as a NOTE: When I bought my Panasonic microwave from AAFES, before I took it home, they sent it through their maintenance department to adjust the internal voltage. Power for the US is 60 HZ. Power in Europe is 50 HZ. Long Technical Explanation shortened: there's more energy (Heat) in 50 Hz than 60HZ especially when used in anything that uses high power. AAFES adjusted the internal power down to compensate and keep from blowing up the unit. Look for a fuse inside. Replace it, then ask AAFES to reconfigure the product for lower power or 50Hz.
Also as a note, many, dare I say most, clocks from the US count the HZ to count time. So if your US clock, say on your coffeepot timer, looses time overseas; it's probably losing 4 hours a day (do the math: 50 hz/60hz=83.333_%. 83.3_%*24 hr=20 hrs or 4 hours lost). So, if your time is set for 7AM coffee start, when you get that cup of coffee at 7:10AM, set your clock forward to 11:10 AM; or at 7PM, make sure it actually says 9PM. It will loose enough time by the next 7AM to be correct.
Aug 11, 2011 | Microwave Ovens
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
Looking for a timer to turn a 120volt 2amp water pump on for 1min 2 times aday that will last for more than 3 years please help
1) You need 120V timer to control 2 amp water pump.
V x A = watts so 120V x 2amp = 240 watt
754 watts per HP divided by 240W = 1/3 HP horsepower.
2) To get 1 minute time periods, you need electronic timer.
Most electronic timers have minimum 1 minute set time.
Same schedule each day, you can use 356-day, 7-day or 24-hour electronic timer.
3) To have electronic timer last longer than 3 years you need a clean circuit and expensive timer.
Use circuit analyzer to check circuit. Hire electrician to check circuit and replace pump if necessary to make sure timer will last as long as possible.
4) Intermatic ET70115C should last for many years. Battery is replaced every 8 years.
ET70115C $379
5) You posted under EH10 water heater timer, which is inexpensive water heater timer rated for 1HP. You can't expect inexpensive timer to last as long when using a motor, although 1/3 HP is lightweight motor.
6) You can buy five EH10's for same price as one ET70115C.
7) List of ordinary electronic timers, each with slightly different features
Intermatic EH10 $73
Intermatic ET1105C $96
Intermatic ET101 $101
Tork EW100B $177
Sylvania SA300 $72
8) See wiring diagrams and manuals for some of the timers listed above:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 31, 2011 | Intermatic 7 Day Electronic Timer Eh10...
I bought a camera from walmart, for my daughters birthday and there is no manual nor is there a battery charger...Walmart said for me to contact you.
Go back to walmart and talk to a manager.. You bought a supposedly new item.. Clearly it is a returned item and missing parts. Ask for an exchange or refund. I cannot believe they would refer you to a self help web site. If you do not get satisfaction you can contact Walmart customer service HQ ans complain. Phone: 800-925-6278 How to reach a live person: Press 2 at first prompt
Press 1 at second prompt
Press 1 at third prompt
Hours of Operation: Mon-Fri: 7am - 9pm
Sat: 9am - 9pm
Sun 12pm - 6pm
All time are CST Description: Pressing 0 or # results in them hanging up on you. or try this one... Phone: 1-800-966-6546 How to reach a live person: Dial 238 as soon as the automated greeting begins (it is not necessary to wait for the menu options) Hours of Operation: 8am-10pm (CT)
Dec 09, 2010 | Cameras
My laptop is only 6 months old and will not boot up.
You will want to contact the manufacturer. They usually have a 1 year parts warrenty on your laptop. The most logical reason is that the mother board(Main PCB) has took a dump. You will want to read the material here:
Good Luck!
Jan 29, 2009 | Acer Aspire 5315 Notebook
My Aspire 5315 will not start
I actually contacted Acer by email for this and got a reply in less than a day.
Try the steps below for a power reset, to eliminate a hardware problem with your notebook:
1. Disconnect the AC adapter from the laptop.
2. Remove the battery.
3. Press and hold the power button for about 30 seconds then release it. (You will not see anything happen)
4. Connect the AC Adapter to the laptop. Make sure the AC Adapter is plugged in.
5. Turn the computer on as normal.
6. Once Windows boots, insert the battery.
If the notebook still does not power on, we recommend the notebook be serviced by our authorized repair depot. You can set this up for service yourself by going to; click on the link for Depot Repair. If you are out of warranty, or you would rather do this via phone, please contact Acer Technical Support at 1-800-816-2237, Mon-Fri 7am-9pm CST and Sat-Sun 8am-5pm CST excluding holidays. For out of warranty products please call 1-866-621-2237. Hours of operation are 7am-8pm CST, Mon-Fri, and Sat-Sun 8am-5pm CST excluding holidays.
Dec 17, 2008 | Acer Aspire 5315 Notebook
Plumbing Logo
265 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
