Question about Canon PIXMA MP160 All-In-One InkJet Printer
Not geting conection - Canon PIXMA MP160 All-In-One InkJet Printer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Canon Expert
  • 259 Answers
Have you connect to PC or lap top ?
Posted on May 23, 2011
My car is not starting
check the fuses under the hood there are a couple of master fuses there also if you turn on the key and the lights go really dim it could be the batery or the startewr try geting a boost failing that check the fuses and conections
Dec 11, 2011 | 2003 Volkswagen Passat
Tip
Fault finder Home electric main fuse
If the fuse in your home is geting down on main fuse. and you dont now wher the fault is. Check: 1 take all fuses down then take the main fuse up. 2 take one after one of the other up then you find the fault becaus the main is geting down when you com to the fault fuse virring. 3 take out all component of the grid on this virring/conection se if the main fuse stans or fall.if it stand, plug one and on into the grid. then you can find the fault component and fiks that/or bye a new one. God luck.
on Dec 04, 2009 | Kitchen Appliances - Others
I have a Pontiac grand am 2004 model and the heater/AC doesn't start blowing until I turn the fan speed up to 4 on the dial what would cause this and how can I fix it?
In most cases it's the blower motor resistor. Below is a diagram of its location, the plug and how to remove it. Looking at the picture of the plug you will want to turn the fan switch to different settings (the ones that don't work as well) and if you are geting power to each of those conections at the plug but the blower motor isn't turning on, this will be your problem. If you are not geting power at the different speeds then it is either the switch or the wiring but like I said the blower motor resistor is common to go. I hope this helps and good luck.
Nov 05, 2011 | 2004 Pontiac Grand Am
It will not crank up
check to see if its not your battery terminals if it has a alot of acid on terminal it could be geting bad conection.
Feb 24, 2011 | 2002 Mercury Sable
Sound sudenly off not continously geting
check speaker cable, ithink this cable didn't conect properly
Jan 08, 2011 | Sansui RZ-8150AV Receiver
When I go to start the car it will turn over. But
WELL YOU NEED TO CHECK VOLTAGE TO STARTER WHEN IT HAPENS TO SEE IF YOU ARE GETING AT LEAST 12 VOLTS TO STARTER WHEN KEY IS TRUNED SO YOU CAN RULE OUT IGNITION THE HOUND S HAVE LOST IGNITION ISUSES OR YOU HAVE STARTER GOING BAD OR YOU HAVE BAD BATTERY GROUND CONECTION OR POSITIVE CONECTION OR BAD CABLES
Aug 12, 2009 | 1997 Honda Accord
Wire conection problem-no manual
Black is obviously ground. red is for switched power (only has power when vehicle is on) single yellow or orange is constant power Dual grey and dual white (solid grey/grey with black) and dual etc. are for speakers. the blue is for accessory power for amps and eq's. on the speaker wires the one with markings is for + and the soild is for -.
May 16, 2009 | Jensen MCD-9424RC CD Player
2003 Chevy 2500HW won't start
recheck battery cables make sure there clean and tight. sounds like its not geting good conection, or starter is bad.
Feb 01, 2009 | 2003 Chevrolet Silverado 2500HD
Hdm ps3
Have you went into the video setup on your ps3 and changed the resolution to 1080p?
Dec 19, 2008 | JVC HD-61Z886 61" Rear Projection HDTV
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
15 people viewed this question
old marine
old marine
