Question about Apple iPhone 3GS Black (16 GB)
I am sick and tired of these guys putting me on the HL every hrs for the past three days, and from what I gather, I am not the only victim. It is really spoiling the game for me and others out there. WHAT CAN I DO???
Trans leak from dip sick
Could be damage from jacking vehicle to change tires. Sometimes lift kits are installed to match oversize tires and clearance might be messed up by putting on smaller tires. Any chance dipstick was already leaking?
Jul 08, 2013 | 1998 Ford Explorer
My tire pressure light keeps coming on my 2007 Saturn Aura. I am generally losing 5 - 7 pounds of air in my tire(s) every couple of days. I put nitrogen in my tires but it was still happening. I went...
Bummer. I suggest three things are suspect: the tire itself, the wheel, and the fill valve. My guess would be the tires, but to get the answer, you remove the tire, and submerge it under water (not easy without a big tool.)
for Tires, go with Michelin. You will NEVER go back to another brand.
Jan 15, 2011 | 2007 Saturn Aura XR Sedan
I have a 94 Rodeo and im sick of the stock size tires. Can i put a tire with wider tread on?...something with meat on it
Yes you can, you have to carful to select a tire for clearance. Any tire shop will be able to advise you what will work.
Jan 13, 2011 | 1994 Isuzu Rodeo
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Samsung S5687 w/hl shuts off after 20 seconds
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 29, 2017 | Samsung DLP HL-P5663W 56" TV
MyGamecube won't read the game disc
buy a new laser from www.jokerface.net and a screwdriver from ebay
Jun 30, 2008 | Nintendo GameCube Console
Apple iPhone 3GS Black (16 GB) Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
