Question about Citizen Skyhawk Eco-Drive JR306059F Wrist Watch
I am not able to correct the month in the date setting on my SkyHawk. I've set the watch on cal in receive mode then closed the crown. I then push and hold the lower button for two seconds waiting for a beep. I've then waited for the watch to beep indicating that it is finished re-setting/adjusting time & date. So far, Its showing the correct day and numerical date for the day but the month is incorrect. It still says 3 ie march for the date... Any suggestions as to how I might fix this? Thank you, John
  • 8,404 Answers
If your watch is still out of whack, please consider reviewong the instructions here: http://www.citizenwatch.com/
If you still cant get it to go, Citizen offers a very reasonably priced repair service.
Posted on Jan 05, 2012
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
How to set day/date on an 1968 DX automatic Seiko watch
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
Mar 09, 2012 | Watches
The day date always now switches over at noon instead of midnight. I've tried to reset it correctly several times, but it doesn't work. what do I need to do?
Hi!
The problem you described is caused by incorrect setting of the hour: AM and PM must be set correctly, AM before noon and PM afternoon.
For more details regarding setting of your watch, please visit Citizen site here:
http://www.citizenwatch.com/COA/English/settings.asp
Please let me know if it helped,
good luck!
Aug 09, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Can,t set timeon watch
OK try and follow these steps and it may help you set the time on your Watch. Once you understand the different function buttons on the edge of the case setting the time will be an easy task.
1-Note the 2 and 4 o'clock function buttons and the crown at 3 o'clock on the case edge of the Citizen Skyhawk Eco-Drive. These buttons set all functions of the watch.
2-Set the home city digital display function at 9 o'clock by pulling the crown to the first position. Rotate the crown until the mode hand in the subdial at 6 o'clock is aligned with TME. Press the 2 o'clock button until the nearest major city where you live appears. Press the 2 and 4 o'clock buttons at the same time to find the home city in the 3 o'clock digital display window. Once the city is selected, the time is automatically set by the automatic radio reception function.
3-Pull the crown out to the first position to manually set the time. Rotate the crown until the mode hand is aligned with the CAL, TME and RX-S position under the umbrella line. Push the crown flush with the case edge. Point the watch's 9 o'clock side in the direction of the radio transmitter. For example, if you live in Los Angeles, point the watch's 9 o'clock side east towards Ft. Collins, Colo., where the transmitter is located.
4-Hold down the 4 o'clock button for two seconds until the tone sounds and the second hand stops at the RX-S position. The second hand will then move to H, M or L found at the 2 o'clock subdial. Remain holding the watch in the same position. The second hand will move from the H, M or L position with the hour and minute hands to the correct time once the radio reception is completed.
5-Press the 2 o'clock button to start the chronograph's stopwatch. Press the button a second time to stop the timer. Press the 4 o'clock button to reset the timer.
6-Pull the crown all the way out and rotate it clockwise until the correct date is selected. Push the crown flush when finished.
IF you are still not able to set the time contact your dealer or the nearest Citizen showroom.
Jan 10, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Describe your Citizen Skyhawk Eco-Drive JR306059F Wrist Watch Problem: How to correct 0 position of 24 four hour hand. I think its done in conjunction with hour hand but how?
Here is how to correct the 0 Position for your watch.
While your the crown of your watch is down in the starting position , turn the crown until the mode hand (this is the circle at the bottom of the face) reaches CHR
At this time now pull out the crown until it clicks two times, two the second setting of the crown.
This will bring the watch to the 0 position correction function.
you can turn the crown clock wise to correct the hour hand.
press the a button to switch hand to second, or press again to switch to minute. Then use crown again to correct 0 position.
The hour and the 24 hour hand is in conjunction with each other.
then push down the crown all the way in and you should be all set.
Oct 18, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Skyhawk SMT date?
You've gotta go to the set setting, one click out on the knob and cycle through all the timezones using the B button (the lower one) to change all the settings to OF (for winter) or ON (for summer time). According to their website FAQ, they can't determine when daylight savings time goes into effect for all the different time zones so there is no automatic changeover from SMT to normal and back again. Disappointing, I know. I just spent half an hour going through their website looking for some master switchover as well.
Nov 01, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Hello. I let a Citizen Black Eagle Skyhawk run completely. Even after charging it for 24 hours, the watch will not run. What is my course of action? Send it in?
After charging the Skyhawk/Black Eagle watch, you need to reset it.
Here's how to do it:
Turn the crown (knob) until it's in chronograph mode (CHR), then pull it out to TWO clicks. Push both buttons at the same time and the display should turn on. The push the crown back in to complete the reset.
If that does not work and you are 100% positive it should've charged...take it in for service. It could be a bad battery (rare).
Aug 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Unable to set time
The time on this watch is set by changing the digital display time then transferring the digital time to the hands.
1 - Turn the crown until the mode hand points to the time mode [TME].
2 - Press either button (A) or (B) to select the city for which the time is to be set.
3 - Pull the crown out to the second click (3) to enter time setting mode.
4 - Pressing button (A) will change the digits to be set. These digits are the ones that are blinking. Press button (A) to select the digits that you want to change.
When button (B) is pressed in the [SMT] daylight savings time correction mode, DST can be turned ON or OFF.
When button (B) is pressed with the seconds digits blinking, the seconds will return to "00".
5 - Turn the crown clockwise to advance the hours or minutes when those digits are blinking.
Although the crown may be turned in either direction, you should always turn it clockwise to the final setting.
6 - When the 12H/24H selection is blinking, pressing button (B) will turn it On/Off.
7 - After correcting the time on the digital displays, push the crown in to normal position (1) to complete time setting.
i think this may solve ur problem
thank u.................
Jul 29, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I cannot set the date on my Citizen SkyHawk Eco-Drive
Just pull the crown out, turn it so that the bottom analog display is set on "CAL" and push crown back in. Voila!!
Mar 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Skyhawk Time Adjustment Problem
It is possible to set the main analogue hour and minute hand 30 minutes out of phase with the digital readout, but doing so will also put the analogue UTC dial 30 minutes off. It can be done by using a variation of the proceedure for zeroing the watch hands as follows: 1. Rotate the crown in its normal opering position to set the watch in chronograph mode (mode dial pointing to "chr") 2. Pull out the crown to the second click. This should cause all the hands on the watch to return to zero. "HR" should appear on the left-hand digital display. This will allow you to move the hour hand by twisting the crown. Advance it to about half way between the 12 o'clock and 1 o'clock positions. 3. Press the top button. "MIN" should appear in the left-hand digital display. This allows you to adjust the minute hand. Twist the crown to advance it to the 6 o'clock, or 30 minute, position. Note that this will also move the minute hand on the small UTC dial to the 30 minute position. 4. Press the crown back into its normal position. 5. Reset the digital time and date according to a time zone that is in a one-hour offset from UTC. This is not a perfect solution. Your digital readings will show the correct time for all one-hour offset time zones while your analogue nads are 30 minutes out of phase. Your small UTC dial will also be 30 minutes out of phase with the digital UTC. Hope this helps.
May 28, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Skyhawk Eco-Drive JR306059F Wrist Watch Logo
119 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
