Question about Lexmark X5650 All-in-One InkJet Printer
How do I send a fax from X5650? Everytime I send them they end up blank
  • Lexmark Master
  • 4,340 Answers
Be sure the face up direction is correct.....Sounds like you may be faxing the back side of your page.
Posted on May 23, 2011
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
How do you load a lexmark X5650 all in one printer, copy, photo, scan, and fax? I am trying to figure out how to load the fax to send the fax to someone.
Sending a fax using the printer control panel:
  1. Make sure the printer is on and is connected to a working phone line.
  2. Load an original document faceup into the Automatic Document Feeder (ADF) or facedown on the
    scanner glass.
  3. From the printer control panel, press the Fax button.
  4. Enter a fax number, or press Address Book to select a number from the Speed Dial or Group Dial list.
  5. Press Color or Black to select a color or black-and-white fax.
  6. Press Start to send the fax job.
Source: Lexmark 5600-6600 Series Fax Guide
May 06, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
I have a Lexmark x5650 all in one unit. I can send fax but not receive fax. What do I need to do
Make sure the correct phone line is connected to the printer and the correct fax number is set in the printer. This article in the Lexmark website will help you identify and resolve your fax problem: Fax Troubleshooting Topics
Apr 16, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How do I change baud rate on Lexmark X5650 in
Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 06, 2010 | Lexmark X5650 All-in-One InkJet Printer
WHY DO I GET A BLANK PAGE AFTER EACH FAX?
The fax machine that is sending you the fax may be also sending a confirmation page that is not needed or compatible with your machine.
I have an older machine that prints a confirmation page after each fax. People on the other end sometimes receive a blank page after each fax that I send them while my machine prints a mostly blank page with only a single line of text at the top with the date and time.
Feb 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
If we send afax than it is coming blank at another
make sure you are placing the document in the feeder correctly. some faxes you have to send it face down others you have to send it face up.
Aug 06, 2009 | Brother Office Equipment & Supplies
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Problems sending and receiving faxes.
  1. Open Lexmak Productiviti studio - 5600 - 6000 Series ( icon on Desktop)
  2. Open Setup and manage faxes link ( left bottom corner)
  3. On Ringing and Answering card look at the Manual Answer Code ( if some nuber inside delete it, it should be blank)
  4. On Dialing and sending card look at the Dial method (if you have a tone phone select Touch - tone, and if you have pulse phone select Pulse)
The diference betwen Touche Tone and Pulse is that Tone when you press nuber hear tone (like on cell phone), and Pulse when you dial nuber hear serie of short pulses (like when you dial nuber 5 you hear 5 short pulses like tttttt)
Mar 24, 2009 | Lexmark X5650 All-in-One InkJet Printer
3150 fax machine outputs a blank page when my fax sends to it
(05) Would you, please, SEND a fax from the machine that blank faxes are being received from to a different recipient on a different fax machine all together, please?
This will enable us to pin down which machine is really experiencing the issue.
Thank you
BJ @:)
Apr 17, 2008 | HP LaserJet 3150 All-In-One Printer
Lexmark X5650 All-in-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
