Question about Emerson EWH100F
I am trying to fix mine, vcr tape won't stop playing when it reaches the end of the tape, keeps breaking tapes. I was told it was the motion sensor, am trying bto locate the part!
    Filmmaker:
    Uploaded 5 video answers.
  • 68 Answers
Find your local authorized Emerson Warranty Center
In U.S.A.
For all product purchased in the U.S., please contact:
Emerson Radio Corporation
9 Entin Road
P.O. Box 430
Parsippany, New Jersey 07054-0430
General questions and comments
internet@emersonradio.com
About my order
Toll-free: 1-800-909-1240 (between 9:00 - 4:00 CST)
Print this out
Take unit in for fix or replacement.
Posted on May 23, 2011
VCR won't eject tape
unplug VCR take the top off about 4 screws or more I would say you willmbe able to see that tape is wound round inside you should be able to remove it .
Mar 16, 2013 | Heating & Cooling
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
PLAYER SWITCHES OFF WHEN PLAYIING VHS TAPES
check any mechanical failure in the vcr unit. like tape won't work properly might some obstruction or plastic broken.
Sep 15, 2012 | Toshiba DVR660 DVD Recorder/VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
VCR won't load tape all the way
Best to check the tape by comparing it with another tape. There could be damage to the case. Check that you can lift the flap at the front. If all else fails or you find damage on the case of the tape, the tape can be removed and placed inside a new blank tape case. The new tape reels would have to be removed first. It's a bit tricky, but as long as you dont touch the tape itself it should work fine.
Jun 07, 2012 | Televison & Video
DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
Apr 29, 2008 | Sony DSR-11 DV / Mini DV VCR
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
DRC 8335 Playing Back VCR Recordings in a Fast Forward State
I bought mine yesterday and am having the same issues. No solution listed in the user manual to fix this and I have a rather extensive VHS tape library that I was hoping to move to DVD using this unit. Unable to watch any VHS tapes taped on my Panasonic VCR and it seems as if the tape is slipping. Tracking buttons don't fix anything. I found a blank spot at the end of the tape and taped something and it comes out fine. Could this have something to do with it being a 6 head VCR? Tapes are in SLP mode.
Jan 08, 2008 | RCA DRC8335
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Machine won't stay on
Hi I'm not familiar with your model, but what it sounds like is a bad "end sensor" on your machine. There are photo sensors on either side of the cassette basket which is what holds the tape in the machine. There is a light source that ends up inside the cassette when loaded, which shines both left and right. There is a section of clear tape inside the cassette at both the beginning and end of the tape. When the sensor on the left side sees light through the clear tape, the VCR knows you have reached the end and goes into rewind, when it sees light on the left side, it knows you have reached the beginning of the tape, and stops rewinding. This sensor is also used in some models to sense when you insert a tape in the basket. In that case, if the right side end sensor goes bad, the VCR always thinks you are trying to load a tape, so it doesn't want to give them up, and when you rewind, it never senses the beginning of the tape, so it will shut down when it reaches the beginning, and could even snap the tape. I'm 99% positive that is what is wrong with your VCR, it is an easy fix, but unfortunately, you won't likely find a repair shop that will sell you the proper sensor. I hope this helps in some way. Good Luck!
Jan 13, 2007 | JVC HR-A592U S-VHS VCR
Emerson EWH100F Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
