Question about Yamaha P3500S Amplifier
ALL THE PARTS ON THE PCB ARE BURNT BIYOND RECOGNETIN
  • mapengs May 23, 2011
    I NEED THE CIRCUIT DIAGRAM SO I CAN SOLVE THE PROBLEM
  • Yamaha Master
  • 5,113 Answers
Your best solution is to contact Yamaha and see if they still stock the entire board and if they recomend replacement. But I wouldn't hold out on it being fixable unless you like to burn your money too!
Posted on May 25, 2011
I have a whirlpool refrigerator ged2fhgxavaoi e22mssa.the display is flashing continuesly and you can't read anything on it.can you help me out with my problem
This is caused by either electrical or radio interference. If left on it will do the following:
1 automatic change of temp set up on display
2 random engagement of solenoid
3 random engagement of water valve
4 damage to main P.C.B.
5 ice maker motor burnt out.
Check the following: Solenoid seized....main pcb burnt out...ice maker motor burnt out.
If none of the above are evident...put on child lock this will prevent any further damage to the above parts until the user interface board is fitted.
Dec 30, 2015 | Whirlpool Refrigerators
Panasonic TH-58-PX60U GREEN LINE
if it does not go all the way across the screen, may be the buffer board controlling that area. you can usually visually check for burnt/overheated parts, then replace that particular buffer. could also be X or Y sustain PCB depending on whether it is vertical or horizontal.Again, you might do a visual for burnt/overheated parts on the particular PCB & replace either parts or PCB.
Lastly , may be panel....not cost effective.
Apr 26, 2014 | Panasonic TH37PX60 37 in. Plasma...
Pcb_w10209636 where can i get this pcb board?
W10209636
Here is a link for you if you like to use them, but any local parts house close to you should be able to obtain this part for you.
Good Luck
Nov 17, 2013 | Whirlpool Refrigerators
Service mannual
look for a like power board on ebay or google,try figure out the missing parts,capacitors?
Mar 19, 2013 | Siemens WXLM112GB Front Load Washer
Hello i have incubator brand suro 20 com king its running but there is no heating a parts burn inside the main controler i like to ask if you can supplied me with the schematic diagram to find the suitable...
I have a king surro with a temperature control fault 2 resistors next to power transistor on pcb burnt out I can tell values of any other components on pcb but does anyone have a controller board who can tell me what value resistors are steve-- protodezine@gmail.com
Jan 06, 2011 | Heating & Cooling
The water in the dishwasher will not heat up
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Oct 25, 2010 | AEG Dishwashers
No power at the power panel( Aqualink RS8)
if unit comes on write down all auxs then remove plugs replace fuse turn on then plug one in at a time till it blows then you know which auw then see if wires are burnt
Apr 25, 2009 | Jandy AQUALINK RS TELELINK KIT
How data can be recover when hard disk PCB burnt
mandyleo
yes, but both hard disk must be identical.
Jun 28, 2008 | Samsung HM160JU Hard Drive
Samsung HCL5515w
Usually if some parts on the board burnt on that model it can be caused by leaky tubes. Meaning the coolant from the crt's has dripped out. If burnt components are beneath any of the tubes, inspect very closely for liquid substance having leaked down from coolant chambers above. If this has happened you must seal leaky gaskets before going through any trouble of pcb repair.If burnt parts are not below tubes, most common cause is bad convergence ic's. At any rate, service info avail online or at samsung.com or 1800samsung. Hope this helps.
May 29, 2008 | Samsung HCL5515W 55" Rear Projection...
Yamaha P3500S Amplifier Logo
44 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
