Question about Emerson Pool & Spa
Where can I get a replacement start switch for my emerson motor cat. # 9352-5104, model # t55wmcbp-1197, I am guessing this is my intermittent problem with the motor starting, as I have replaced the start capacitor and made sure the centrifugal actuator is not sticking.
  • Emerson Master
  • 1,343 Answers
I WOULD SEARCH FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING. BRING IT IN AND SEE, CHANCES ARE HE WILL GIVE YOU ONE ! , JUST TO GET YOU OUT OF HIS HAIR .. IT'S BEST OFF TO LET A PRO DO YOUR PUMP REPAIR.. YOU CAN SEE WHAT HAPPENS WHEN YOU TRY TO FIX IT.. MOST MOTOR REPAIRS ARE AROND 75.00 AND COME WITH A FREE SHAFT SEAL..YOU CAN ASK HIM WHAT YOU ARE DOING WRONG, WHY MOTORS DON'T LAST. IVE HAD MOTORS OVER 40 YEARS OLD IN MY SHOP, I LOVE FIXING THEM, AND SENDING THEM BACK TO WORK.. NOW THAT'S KOOL .. REMEMBER TO PRIME THE PUMP.. JAY... THAT POOL MOTOR FIX'N GUY IN LONGWOOD FLORIDA
Posted on May 26, 2011
I am trying to find a replacement basket for a emerson pump model T55CXCLL-1386 Cat EQC1072 HP 3/4
Emerson does not make pumps. They produce a motor, as a third-party vendor, and a pump manufacturerer will use their motor.
so, the information you provided, is for the motor, we cannot assist you to locate a basket for your pump, with those numbers. Provide us a make and model of the pump. If you can't, take a picture of it, and upload that.
Some information... Or terminology, that might make things a little more clear:
A motor is the electrical component that is attached to a Wet End.
The Wet End or the Liquid End houses the impeller which is what moves the water when the motor begins to turn.
The two together make a Pump.
The Motor by itself, is not a pump. The wet end, is not a pump by itself. Again, the two together make the pump.
Common names/brands of pumps: WaterWay; Hayward; Pentair; Sta-Rite (now Pentair), Jandy, among others.
Apr 02, 2015 | Emerson Pool & Spa
Show picture how to replace pot gasket in emerson pump s55nxnpk-7243
Emerson - to my knowledge, does not make pool/spa Pumps!
Just motors.
Then pump manufacturers utilize Emerson as a 3rd party vendor to supply them with a motor for their Wet End. Then when their Wet End is installed onto a motor, like Emersons, then is it called a Pump!
make and model of your pump?
Feb 26, 2014 | Emerson Pool & Spa
Intermittent wiper
what car, what year? gee? a suz, what?
it can only be 4 things. (all cars)
1: the wiper motor is bad. (it has contacts inside for timing.
2: the wiper shaft is stripped, nah you said both stalled.
3: the wiring is bad.
4: the combo switch for the above is bad.
DIY, with what , no tools? no meter.?
with no tools one can only GUESS,
roll dice, and replace a part.
after spending $500 on parts and the wires are good then what.
yes, buy a meter.
it could be a bad ground wire.
when you turn on most wipers, the combo switch sends
that signal( just 12v ) to the motor.
the motor is self booting, that is , it only needs the start up
and then it self provides its own power,
ive restored wiper motors, many.
then the motor runs until it his the dead spot in ITS, internal
sustain switch and the halts. if the combo switch is off.
but if the wiper fails to return, this is a bad wiper motor.
(overloaded by ice, sure)
the motor can fail 2 ways, but
id say the sustain switch is at EOL. end of life.
this is the most common design.
check your FSM for yours. the factor service manual.
or alldata dot com. sure.
Sep 25, 2013 | Suzuki Cars & Trucks
Hi Mike, I have a DOERR Emerson 2,25kw motor on my
Check the start/run capacitor first. If that is OK replace the motor as there will be a problem with the windings.
Aug 24, 2017 | Kitchen Appliances - Others
Replaced old Sta-Rite pool motor with new 1.5 hp Emerson 1081 pool motor. Used exiting 240V wiring. Wired L1 to 120V (black wire), L2 to 120V (red wire), Ground to green ground Screw (green wire). Turned...
Get qualified electricrian to help. I've had the same problems with my pool pump. If you make one little mistake, it could be your last.
Oct 05, 2011 | Pool & Spa
I am looking for a starting switch for an Emerson motor it is a 2 speed motor # 1081 and 1795
look on ebay for... ask if you have a 2 speed switch ? fixya
Pool pump centrifugal start switch AO smith OR emerson
Aug 15, 2011 | Pool & Spa
Hello, I have an Emerson Spa Pump Motor ( 2 HP, 230v, 3450 rpm). The motor has model R610867, cat 7610, sf 1.3 on it. It also has "1081 motor" on the label. I am tring to find a...
should be a 30, you can have the old one tested it might be good ? I write the value on the back and side for future reference to avoid this problem as the value is normally not stated on the motor's label like is done on air conditioning motors. search your area for your LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING
Jun 03, 2017 | Emerson Pool & Spa
Where can I find parts for the old emerson electric motor in my spa? it is an emerson c55cxfby-3475 and I am looking for replacement springs that are for what appears to be a centrifical or heat control...
You're most likely looking at the starting circuit centrifugal switch. It is probably not cost effective to try and repair that motor. Depending on HP and frame, you should be able to buy a new motor for 100.00-200.00. Instead of buying from a pool company, buy from a motor shop or from a place like www.grainger.com Main information to have if replacing with different mfg will be HP, RPM, Voltge, and important frame number.
Jul 24, 2010 | Emerson Pool & Spa
I have Emerson mcirowave model AT1120. Everything works fine except the turntable does not rotate. How can I fix this? thanks.
Not an Emerson answer, but a reasonable guess based on what I found working on other names:
Three reasons it will not rotate, 1) the motor does not get the command to rotate, 2) the motor gets the command but it is dead, 3) the little driver doojig is broken. This part locks to the motor with several interlacing fingers - pull it up to remove.
In my experience, you can replace the motor and you can replace the doojig that the motor turns to spin the plate.
I hope this helps you solve your problem.
Thanks
Oct 18, 2009 | Microwave Ovens
Pool & Spa Logo
424 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
