Question about GE Profile Prodigy WPSE4200A
Ge washer # WBVH6240FWW
My washer will not spin or drain water. The drain hose is not clogged or kinked,the washer does spin for approximatly 10-15 sec and then stops..so the drum will spin. any ideas?
  • keatsb Aug 24, 2008
    When the repair man/women comes to my home I will certainly post the results...I plan to call to schedule labor day weekend.
  • jennmantis54 Jan 05, 2009
    We have a similar problem, the wash cycle spins, but once the water level is at a certain point, it does not spin any more nor does the water drain.  We have checked the hose and there are no kinks or clogs that we can tell.  It just makes a clicking noise like it is trying to move on to the next step of the wash, but it doesn't and my clothes stay sopping wet and the excess water is not drained.
We have a GE washing machine that works fine with no load, but will not finish the cycle with a full load.
Posted on Apr 12, 2010
  • 639 Answers
Appointment department is open 24/7 but i''m not sure if they repair 24/7
Neil
Posted on Aug 25, 2008
Washer won't drain
the drain hose is on the back. it's generally the biggest hose on a washing machine and in most cases black. it could be kinked or clogged. once you locate the hose it's held on with a clamp. undo the clamp and it pulls right off. if no clog or kink there follow the hose to the drain usually on the wall and look there. I doubt it would be or else you would have water all over the floor so my guess is it's not even leaving the washing machine. Also something to keep in mind is that it could be the pump that draws the water out.
Jul 14, 2012 | GE Spacemaker Washer and Dryer Electric...
GE Profile model WPRE6100 only spins slow....
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Oct 02, 2010 | GE Profile WPRE6100G Top Load Washer
    My front loading GE washer WSSH300 will not drain.
    Don't know if this will help or not, but your owners manual is available at http://genet.geappliances.com/DocSearch/Dispatcher
    Water won’t drain
    Drain hose is kinked or •
    Straighten drain hose and make sure washer is not improperly connected sitting on it. Top of drain outlet should be less than 8 ft. (2.5 m)
    above floor. Household drain may • Check household plumbing. You may need to call be clogged a plumber. Plumbing this washer directly to a pipe is hard on the motor. Usually the drain hose elbow is inserted in a stand pipe, meaning the washer would drain water on the floor is the stand pipe is clogged.
    Several items can cause the lack of draining.
    If you can get to the drain hose, try lowering to a point that it will drain into a bucket. If it drains the system is not clogged. If you advance the timer and the washer drains this maybe the culprit. The motor can overheat and shut off. I would advance the timer to spin and listen for a hum in the motor and then quiet, a sign that the motor has overheated. If the water drains it sounds like the timer is at fault.
    I would first make sure the drain hose is properly installed and not kinked somewhere. In earlier GE's the water drain pump could clog, your manual doesn't indicate that as a defect. Regardless timer, motor and pump are in the cycle to empty the washer water.
    Jul 10, 2010 | GE WSXH208A Front Load Washer
    Water wont drain out
    1)A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem
    2)If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
    3)Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
    If all of the above steps fail to produce a washing machine that drains, then it is time to call a professional repairman.
    Thank you !!
    May 25, 2010 | General Electric WSSH300G Front Load...
    Machine will not drain or spin
    Please donot forget to rate and accept my answer...
    Un plug the washer again for 30 seconds plug back in press the start/pause button then press power...This will try to reset your washer.. If it didnt work your pump must be checked...
    Apr 19, 2010 | Roper RAS8445KQ Top Load Washer
    GE top load washer will not advance to drain and spin
    Apr 15, 2010 | GE Profile WPRE6100G Top Load Washer
    Washing cylce completed but is not draining to begin the spinning cyle.
    Apr 14, 2010 | Fisher and Paykel Washing Machines
    Water not draining during spin cycle - softener not dispensing into rinse cycle
    Just make out the following checks before calling a repairman.
    Aug 30, 2009 | Amana Washing Machines
    Wisr409 machine can't spin
    hi friend,
    Step 1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
    Step 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
    Step 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mowermag-glass_10x10.gif or even a bicycle chain should be able to accomplish the task.
    Step 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
    Step 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
    thank u for using fixya
    regards,
    sivaranjini
    Aug 06, 2009 | GE WBSR3140DW Top Load Washer
    Ge front load washer won't go into rinse cycle.
    Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
    Jun 03, 2009 | GE WSXH208A Front Load Washer
    Washing Machines Logo
    648 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
