Question about Fedders A3X05F2A Air Conditioner
I have a damaged plug on my Fedders A3X05F2A air conditioner. I cut it off but can't tell which is the white and black wire to attach to replacement plug.
    Brigadier General:
  • 4,736 Answers
Have you tried to carefully strip the outer insulation off the wire, to expose the 2 or 3 inner wires? If not, doing that will give you the color codes.
Posted on May 23, 2011
  • 2 more comments
  • mrribonz May 23, 2011
    Have already done so...Only the ground wire has a sleeve the other ones do not. Followed the wire inside until it split. Is the wire to the capacitor the white wire??
  • Rich Landrum May 23, 2011
    The White wire is the Hot or Positive wire. Black is the Negative. If I were you, I'd try to find a complete cable with the plug intact at Appliance Factory Parts http://www.appliancefactoryparts.com/cus... . That way, it will have a molded plug and not have to worry about which wire goes where.
  • mrribonz May 24, 2011
    Never mind got it figured it out!! Thanks for your help~The black wire is connected to the on/off switch~~
    Thank you!!
  • Rich Landrum May 24, 2011
    That would be correct. You interrupt the negative to turn any electrical appliance ON & OFF. Good man!
I have a Fedders air conditioner but cannot tell if it is 110 or 220. the numbers are 146y and SN #141448
Well 110 v will have black, hot, white, neutral and green for ground. 220v usually will have black, hot, red, hot, white neutral wires. hope this helps.
May 20, 2017 | Fedders Heating & Cooling
How many btu's does the fedders model # A6X05F2A have?
The unit should have a boiler plate behind the front panel indicating btu's and other electrical parameters. Look for it. Or Google the unit
5000 btu..
Jun 01, 2014 | Fedders A3X05F2A Air Conditioner
LOST INSTRUCTION MANUAL-CAN YOU GET ONE ONLINE
Check on their website. Most electrical things do, yes. It's finding the site that's a problem.
Aug 17, 2011 | Fedders A3X05F2A Air Conditioner
Fedders A6X05F2A fan has stopped working, and therefore air conditioning has stopped. Could the fan be the problem (or just the dirt and gunk I have to clean out?)?
Honestly, it could be either one. But, to save on costs, clean out "dirt and gunk" first. Be sure the unit is turned OFF and unplugged before attempting any cleaning. FYI - Hosing it out does not count as cleaning. And could do more damage than good.
Hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Fedders A3X05F2A Air Conditioner
My unit is 220v single phase ----the wiring in the wall is one black, red, white and a ground wire ----what is the proper connection to the outlet
The black is a 110 "leg" the red is a 110 "leg" the green is ground and the white is neutral. Not sure of what type receptacle you have but the black and red are
the hots and the white is connected to the neutral and the green is connected to the
green screw or terminal or wire that may be attached to the box itself.
The receptacle should be marked "Hot" or ACTIF on the hot terminals or identified
by reddish colored or gold screws. The neutral should be a silver screw. Make sure
power is off at the panel and check with a meter or tester before proceeding.
If you have any doubts, please contact a licensed electrician to prevent damage.
Jul 23, 2011 | Fedders A3X05F2A Air Conditioner
Leaking inside. Fedders A3X05F2A-J Unit is sloped away from house. Have sprayed coils. Doesn't seem to be drain hole at back of unit
Mellisia, the problem very well may be, that the drain pan hole under the unit, on the outside may be clogged. When that happens, water backs up and leaks out the front of the unit.The drain hole should be near one of the corners of the drain pan. And with Fedders, it may be on the edge/lip of the drain pan. The clog, may appear to be part of the drain pan and that's why you haven't noticed it.
Inspect the drain pan closely. If you can't find it. You can create one, by CAREFULLY drilling a hole at one of the corners of the drain pan. It doesn't have to be a large hole 1/8" to 1/4" should do.Be sure the unit is OFF and unplugged from the wall, before attempting this. Also, once the drill bit penetrates the drain pan STOP. You don''t want the drill bit to pierce the coils on the back of the unit.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | Fedders A3X05F2A Air Conditioner
WIRES UNHOOKED FROM CAPACTOR
on a capacitor with three diff conections
1 is for the condensor fan it will say fan on top of the capacitor usually 5mfd. just look at the wire colors. on the fan motor
2 is the common wire usualy white however not always.the top of capacitor will say C this will be tied into the ground usually like your house common.
3 this is for the compressor the top of the capacitor will say herm, trace the wire that is going inot the compressor.
i would just like to know why the wires are off. it could be the capacitor is bad or the compressor was not coming on and someone thought it was the capacitor.
ALSO MAKE SURE YOU GROUND THE CAPACITOR WITH A SCREWDRIVER TO THE CHASIS you will get shocked
Sep 15, 2009 | Fedders A3X05F2A Air Conditioner
Fedders A3X05F2A Air Conditioner Logo
106 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
