Question about MSI Computers & Internet
I need a number for msi computers so i can have them open a port on my router and i can not find one for the life of me the name of the company is microstar international.
    Master:
  • 441 Answers
Try this link: it has instruction on opening port for different routers.
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Posted on Aug 16, 2008
How do i set up my router msi
Is that a standalone router or a modem/router combination ? If it is a standalone router, in order to set up a home network to access the Internet, you need a modem (cable modem or DSL modem) which must be given to you by your Internet provider when you subscribe for Internet service. Your Internet provider has to provide instructions on how to set up your modem. A modem acts as a router too and has a WLAN port and a number of LAN ports (between 1 and 4). The WLAN port is where you hook up your modem to the Internet using an Ethernet cable. One end of the Ethernet cable goes into WLAN port of the modem/router and the other end goes either into a cable outlet (if your Internet provider is a cable company such as Comcast) or a phone jack if your Internet provider is a phone company such as AT&T or Verizon). To connect your desktop computer to the Internet, you plug it in any of the LAN ports on the modem/router. Contact your Internet provider for set up instructions for your specific brand and type of modem.
Hope this helps.
Dec 13, 2014 | MSI Computers & Internet
Cannot forward my port
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
May 18, 2009 | Computers & Internet
Im laggin on psu a game only 1 connection it only du it once a few days n it lasts 4eva please help its to do with modem or router
You need to do port forwarding. Call PS3 tech support to get the port numbers to opened to your Netgear Router. And follow this procedure.
Port Forwarding
A. Determining the IP Address and MAC Address of your PS3:
2. Connect to the router by typing or http://192.168.1.1 or http://192.168.0.1 in the address field and click Enter or Return key.
Apr 26, 2009 | NetGear MR814 Wireless Router
I cannot reconnect my wireless router back to my computer
A. Determining the IP Address and MAC Address of you PS3 & Wii:
D. Opening Ports for Games, Applications or Custom Ports (Call PS3 tech support & Wii support to ask for the port numbers to be registered onto the router):
Apr 21, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Problem connecting with mates on fifa 09 on ps3.
here is the link for your port forwarding configuration:
http://kb.netgear.com/app/answers/detail/a_id/1166
here is the link for HOW IS PORT FORWARDING CONFIGURE:
http://kbserver.netgear.com/kb_web_files/n101145.asp
Instructions for RP614, MR814, WGR101, WGR614, WGT624, WGT634U, WGU624, WGM124, or WPN824 These routers do port forwarding by assigning port numbers to a "service" that is associated with the application you want to run.
To Let an Application Use Port Forwarding
  1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). The Setup Wizard appears.
  2. Enter the router's username and password.
  3. Under Advanced, click Port Forwarding on the left menu bar.
  4. A Port Forwarding Screen (Varies Slightly by Router)
  5. From the Service & Game (or Service Name) pull down, select the service that you will host. The services the router knows about are listed here. If the service does not appear in the drop down, add a service as described in the next section, then return to this step.
  6. Enter the IP address of your local server in the Server IP Address box.
  7. Click Add.
  8. Click Logout to exit from router settings.
To Add a Service for These Routers
To define a service not in the Service Name list, determine what port numbers are used by the service.
  1. Click Add Custom Service.
  2. Enter the first port number in an unused Start Port box.
  3. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box.
  4. Enter any name you choose for the service.
  5. Click Apply.
Apr 03, 2009 | NetGear WGR614 54Mbps Wireless Router...
Cant enable port magic on router need usr name & password
By default;
Username: admin
password: password
Here are other steps you may want to consider in opening some ports on your router.
Port Forwarding
Mar 17, 2009 | NetGear WGT624 Wireless Router
Need to open port on a netgear
A. Determining the IP Address and MAC Address of a Computer (street fighter1v):
Feb 01, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Netgear dgn 2000 port trigering
Port Forwarding A. Determining the IP Address and MAC Address of a Computer: Note: Please use the computer for which the Ports are to be opened: For Windows 2000/XP users: 1. Please click on Start and select Run. 2. Type in cmd and click on OK. 3. In the Command Prompt, please type ipconfig/all then press Enter or Return key. 4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). 5. Please note down the IP address and Physical address. B. Reserving an IP Address: 1. Please open any web browser like Internet Explorer or Netscape Navigator. 2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. 3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password". Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it. 4. When the setup page opens, click on LAN IP Setup under Advanced tab. 5. Click on Add under Address Reservation. 6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table. 7. If the computer you want is not on the list, please click on the Refresh button to update the table. 8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add. 9. Click the Add button when done. C. Opening Pre-Defined Ports for Internet Services: 1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu. 2. Please select the service type Port Forwarding. The router pre-defined services are listed there. 3. From the Service Name pull down list, select the service that needs to be hosted. 4. Enter the IP address of the computer in the Server IP Address box. 5. Click the Add or Apply button. 6. Repeat all steps to open more ports. Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below: D. Opening Ports for Games, Applications or Custom Ports: 1. Click on Add Custom Service button. 2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box. 3. If the application uses only a single port; type in the same port number in the Ending Port box. 4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box. 5. Type the IP address of the computer in the Server IP Address box. Click Apply button. 6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation. 7. Repeat all steps to add more ports for more services. E. To Edit or Delete a Service Entry: 1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page. 2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Dec 25, 2008 | NetGear RangeMax WPN824 Wireless Router...
NAT
A. Determining the IP Address and MAC Address of a Computer/Game Console (PS3, XBOX, Wii, etc...):
NOTE: Port numbers can be provided by Tech support of each Console game Manufacturer..You can call them first...
Jun 19, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
How to install netgear fvs318 vpn firewall?
Dec 15, 2007 | NetGear FVS318 Cable/DSL ProSafe VPN...
Computers & Internet Logo
46 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
