Incomplete transmission tx/rx no. 0002: color transmission result: NG #18
SOURCE: faxing
That is the same problem that I have. I think the settings for the fax have to be reset. I am calling canon to get help.
Posted on Jul 05, 2008
SOURCE: Canon Pixma MX700
I had the same problem. Solution? I will sound stupid, but it worked for me. Check every phone cable. Unplug and replug it. I solved my problem by making my connections simpler. I think, one of my splitter was faulty.
I still not understand why. I tried to fax without any phones plug-on and it was not working neither.
I'm with "videotron.ca" for my phone line and I unplugged the line from the modem too, then replug it. Maybe it was just that!
A lot of people seem to have this problem. I called Canon twice and they made me change some setting in my printer but their solutions was not working. I put all the setting back to what they was and it still working now.
Posted on Nov 20, 2008
FixinFax
  • 3085 Answers
SOURCE: Incompleter transmission causes? Result NG?
It means No Good. 5 possibilities:
Receiving machine unplugged
Not a fax number
Wrong fax number
Busy signal
Digital Phone Line
Posted on Jul 17, 2009
SOURCE: Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Posted on Jul 30, 2009
komguy
  • 2306 Answers
SOURCE: No fax transmission
Plug the phone line into the plug marked L on the back, make sure you are dialing the full number, The fax won't work in an office with digital phone service, you need an analog phone line like at home. In fax setup you need the type of dialing set properly, tone or pulse dialing, check also with Canon support, 1-800-828-4040
Posted on Feb 01, 2010
Can you please tell me how to print Fax activity report each time? means whenever I send a fax I need confirmation receipt thats its gone through.Can't find anything in Manual.
ACTIVITY REPORT
The FAX is factoryset to automatically print an ACTIVITY REPORT after every 20
transactions. If you want to print an ACTIVITY REPORT before it is automatically
printed, follow this procedure:
Transactions in an ACTIVITY REPORT are listed chronologically.
1 Press Function.
2 Press Report.
3 Press OK.
• The FAX prints an ACTIVITY
REPORT.
• If you prefer the FAX not to print an ACTIVITY REPORT after every 20 transactions,
disable the ACTIVITY REPORT setting ( p. 145).
• Please note that only one transaction number (TX/RX NO.) is assigned when you send
a document to several fax numbers in one operation.
ACTIVITY REPORT
PRINTING REPORT
27/12 2002 15:00 FAX 123 4567 CANON 001
ACTIVITY REPORT
ST. TIME CONNECTION TEL CONNECTION ID RESULT
* 27/12 13:43 905 795 1111 Canon CANADA 5001 AUTO RX ECM 1 OK 00'33
* 27/12 13:45 905 795 1111 Canon CANADA 0001 POLLING RX ECM 0 OK 00'00
0 STOP
* 27/12 13:51 03 3758 2111 Canon TOKYO 0002 B'CAST ECM 3 OK 01'18
* 27/12 13:53 2 887 0166 Canon AUSTRALIA 0002 B'CAST ECM 3 OK 01'18
* 27/12 14:10 905 795 1111 Canon CANADA 5002 AUTO RX ECM 1 OK 00'18
* 27/12 14:16 2 887 0166 Canon AUSTRALIA 5003 AUTO RX ECM 4 OK 03'59
* 27/12 14:27 20 545 8545 Canon EUROPA 0003 DELAYED TX ECM 1 OK 01'20
27/12 14:30 20 545 8545 Canon EUROPA 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:31 03 3758 2111 Canon TOKYO 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:57 2 887 0166 Canon AUSTRALIA 0005 TRANSMIT ECM 3 OK 01'25
0 STOP
27/12 14:59 1 432 2060 CANON OPTICS 0006 TRANSMIT 0 OK 00'01
0 #018
go to this site to download manual (see page 11-3)
http://files.canon-europe.com/files/soft30110/manual/FAX_L220_L295_UG_ENG.pdf
Dec 16, 2010 | Canon L220 Plain Paper Laser Fax
INCOMPLETE TRANSMISSION RX FAX INFO MATCH
Hi have you tried to send faxes to another number ?
Feb 18, 2018 | Canon PIXMA MX310 All-In-One Printer
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Dec 12, 2009 | Office Equipment & Supplies
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
Need user manual for Terapin TX-0002
Do an internet search for Terapin TX-0002. Go to the Amazon page i the results. Aways down on the page you will see a link to download the manual in pdf format.
Aug 05, 2009 | Terapin TX-0002 CD-R Burner
Not a fax number
Wrong fax number
Busy signal
Digital Phone Line
Jul 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Jun 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MX700
Oct 31, 2008 | Canon MX700 Office All-In-One InkJet...
153 people viewed this question
k24674
jasbo
jasbo
