Question about Prestige Remote Start
Bought a 2002 jetta that has a prestige remote start on it. it worked fine a few months. Today nothing works..it won't start, or even trigger the start sequence, and the door lock/unlock won't work. The remote still shows a green light every time i press a button so I don't think it's a battery issue. Any suggestions?
  • akartsb
    akartsb May 23, 2011
    Does the car start? Is there power if you turn the key to the ACC position?
  • Anonymous Mar 19, 2014
    I have prestige remote with display. It is dead. No display. Battery was change on it. Nothing. Please help
  • Audiovox Master
  • 625 Answers
There are two possiblities that could prove to be the fault; hood pin switch and remote start shutdown switch. If the vehicle is equipped with a hood shut down switch, you will need to make an adjustment to it for the remote starter to function. Search around the drivers side edges of the engine compartment for a push pin.If the pin is a stand alone it will be mounted near the headlight inserted into an existing hole. It may also be attached to a bracket. The remote start shutdown switch is a toggle switch located under the drivers side of the dash,usually to the left of the brake pedal, depending on the installation.
If nothing above solves the problem, you may need to reprogram the remote to the unit.
Posted on May 24, 2011
Prestige APS-51
This forum is for Cameras. Please repost in a forum dealing with either electronics or motor vehicles. Thank you
Jul 13, 2017 | Audiovox Prestige Aps51 Car Remote Starter...
2006 Jetta 2.5 battery died, jumped car, radio won't turn on
Take it in to have a charge system check done on it, Your alternator is probally shot,
Nov 27, 2012 | Cars & Trucks
2007 VW jetta cd player won't read any cd
More than likely would be cheapest to just replace it. useually this is what most do,cheaper that way....hope this helps and if so Please rate my post
Aug 15, 2012 | 2007 Volkswagen Jetta 2.5 Sedan
Our 2007 Jeep Grand Cherokee randomly won't start.
change the wires that go to the starter i had the same problem fixed now with no problems
Jun 20, 2012 | 2005 Jeep Grand Cherokee
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
Car 97 camry wont start but lock and unlock work
Won't start with the key? The issue is with the car. Won't REMOTE start, the issue may be with the hood pin switch (located under the hood) or, if it's an older system, the issue may be with a toggle switch under the dash.
Apr 25, 2011 | Prestige Remote Start
Hi I have bought a new Prestige Induction cook top. I have been using it for quite some time, but without any problem. All of a sudden today when I try to heat water , the temperature panel goes to E3...
I have bought a new Prestige Induction cook top. I have been using it for quite some time, but without any problem. All of a sudden today when I try to heat water , the temperature panel goes to E3 and nothing else works.
In order to start it again I have to switch off the power and start all over again.
Please help me in fixing this problem
Oct 28, 2010 | Microwave Ovens
Prestige Remote Start Logo
901 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
