Kenmore washer The dispenser drawer on our washer fell out and the magnet in the drawer became dislogded. I cannot figure out where it goes on the drawer to get the machine to sense that it is fully pushe in. any suggestions?
    Genius:
  • 1,028 Answers
Pull drawer out on right side just behind outer cover there should be a area where magnet fits if can't find exact spot hold magnet along right edge of opening and turn washer own if nothing happens move magnet along right edge till it comes on glue mahnet to dispenser drawer in corresponding area
Posted on Aug 16, 2008
SOURCE:
Our magnet fell out, where does it go
If you are talking about a small, rectangular magnet, about a 1/16" think or so, it goes in the detergent dispenser drawer. Looking at the front of the drawer, right side, a little behind the front. This magnet triggers a ( or should if its not falied) a magnetic reed switch which allows the washer to operate only if the drawer is closed.
If you take the drawer out, and remove the front, you will see where it goes.
Apr 26, 2010 | Frigidaire GLTF2940ES Front Load Washer
Magnet fell out of the soap dispenser and now the washer will not fill with water
The magnet needs to be located on the right side of the dispenser housing it is there so the machine knows the drawer is closed. The link below will show the location of the magnet which is part number 51 near the bottom of the page.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0503093-00001.png
Apr 20, 2010 | Frigidaire ATF6000ES Front Load Washer
Magnet fell out of dispensing drawer and I don't seem to be able to find where to replace it. Washer will not start without it. Kenmore model 417 44152400
I dont see why there would be a magnet in the dispenser draw in the first place,,,, is it possible it somehow got in there by accident and when it fell out you thought it belonged in there ?
Mar 12, 2009 | Kenmore 46462 Front Load Washer
Kenmore 417 starts then stops when water doesnt come out.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 01, 2009 | Kenmore 44042 Front Load Washer
Frigidaire gltf2940e front loading washer - dispenser drawer magnet replacement
When you are looking at the drawer, the magnet stands upright on the far right side just inside the outer front casing about halfway down. There is a small plastic clip that holds it in place. You don't need to take anything apart to reinsert the magnet, just open the drawer, but it may be easier to see the location if you pull the drawer all the way out of the hole.
Nov 02, 2008 | Frigidaire GLTF2940E Front Load Washer
Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Oct 22, 2008 | Frigidaire GLTF1670A Front Load Washer
Not filling with water
Answer: The magnet goes on the back of the dispenser door. Pull entire dispenser out per instructions elsewhere in manual as if you were going to clean it. Turn it around so that you are looking at it from the back end. The magnet goes vertically on the very left edge (as you're looking at it, right edge when dispenser is in machine) of the back of the white outer cover of the dispenser about halfway down. If you run your finger along the left edge (the edge of the back of the dispenser) you will find a "cut out" area. The magnet goes immediately to the right of it between the edge and the portion of the dispenser that sticks further out toward you. There is a small clip to hold it in place.
I found instructions somewhere on the web similar to these that helped me locate it , but can't find it now to link or give credit. I have added some photos I took to help schematically challenged folks like myself.
PS If you need bifocals remove the front cover from the dispenser, take your glasses off and look at the far middle left of the back of the dispenser cover. It's really hard to see.
a4fbef54-7dc5-4c60-815f-e92937ca670b.jpg 6bc37cd8-9f56-4605-b13e-03c400a840ab.png
Jul 31, 2008 | Kenmore 43142 Front Load Washer
Frigidaire + ddo error code
Excellent solution. I had a similar problem. The trick is to figure out where to put the magnet. I had a hard time with that.
For those like me who might have difficulty finding the spot for the magnet, it goes on the right hand side of the detergent door. The easiest way to do it is to pull the detergent door all the way out of the machine and look at it such that the back of the door is facing you. The magnet fits vertically in a slot on the left side as you are looking at the door (right side of the doorwhen inserted in the machine) in the white plastic. It sits vertically and is held by a small latch. This is not obvious at all...
Jun 25, 2008 | Frigidaire GLTF2940ES Front Load Washer
My door lock magnet fell out and I don't know whee to put it back on the dispensr mechanism tomake t lock
I found it! If you are looking at the drawer from the back the magnet sits in the pocket in the far left. The plastic extends out like a clip (to hold the magnet in place). You depress that when placing the magnet in.
hth.
Kate
Aug 15, 2007 | Kenmore 43042 Front Load Washer
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
