Question about Gaggia Baby Espresso Machine
Gaggia Baby Ivory, 2 weeks old.Hot coffee spurts out of side of brewing head when brewing. I called your Philips help line & was told that I had to insert a plastic disk, which is not shown on the parts list in the instructions under the cup filters. These do not fit under the cup filters & so i assumed that they need to be inside the cup filter with the coffee. This just melted one of them. This is not good Gaggia! Can you advise please.
    President:
  • 1,618 Answers
If coffee is brewing out the side of the head then the group gasket needs to be replaced because it is damaged or there might be coffee grounds stuck to the gasket and it needs to be cleaned using a brush or you can also use cotton swabs.
Posted on May 24, 2011
Baby gaggia no water flow for espresso
I helped my father to fix two of these machines that had this problem. He never uses the steam, only making crema coffee all day long, every day.
It is not easy to fix, but its not complicated either. If there is no water flow from the brew group, but still steam, that means the brew group has gotten clogged with Calcium.
When you take it apart you will be amazed.
You will need a very short and fat Philips head screw driver.
Like this:
http://www.amazon.com/Short-Stubby-Screwdriver-2-piece-Set/dp/B001CWHUDA
or similar. Any hardware store will have it. 1st step is to turn the machine on its side on a soft surface to protect from scratches.
Remove the brew head and look in the brew group where you prob. haven't looked before. You will see a screen with a Phillips head screw in the middle. You need the screw driver to remove that screw. It is like almost melted in from the high heat so you need a Phillips with a fat head so as to not strip it, and a thick handle to apply a lot of torque. And you will need a bit of strength.
If you make it past this just hit me back and I'll tell you more. Or hit me if you have any other questions about this step, or at all. Believe it or not, there is more stuff past the screen.
Jul 13, 2014 | Gaggia Baby Espresso Machine
Have a new Gaggia baby and when I use it it spits hot liquid sideways which is dangerous, what do i need to do?
Mine does the same but when i use the creama addition to the brew cup it stops. The book only states that you use it for the large 2 cup but i use it for both
Jan 02, 2011 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine - water comes out of steam wand but not group head. tried priming, cleaning
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Oct 21, 2009 | Gaggia Baby Espresso Machine
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Jul 13, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Classic Spurts Everywhere
Hi there if your coffee is spurting out the sides it is because the group gasket is worn or has gone hard through use and now needs replacing. Basically when you twist your coffee handle on it doesn't always form a perfect seal and so the pressure causes the coffee to spurt out the sides. If you are not sure where to get parts get in touch with David at coffeeservice@live.com and he will be able to sort you out.
All the best
LaPavoniBoy
Jul 13, 2009 | Gaggia Classic Espresso Machine
Baby gaggia steamer doesn't work
Does the machine brew hot coffee? If yes, then remove the parnello and clean the holes at the end of the steam wand. If that does not solve problem, then it is blocked where valve is connected to boiler, Try descaling machine. If no then the thermostat on the boiler has tripped and needs to be reset.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Gaggia Baby Espresso Machine Logo
165 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
