My volume is extemely faded, no matter how i i turn the volume up, and when i turn it up to around 60 there is no volume at all.
  • mdsrule84 May 23, 2011
    The volume works fine with a DVD player
  • 6,993 Answers
first, connect the TV to a DVD player and observe if there is going to be sound.
If there is no sound, connect an headset to the earphone jack of the TV. If there is still no sound, then it is confirmed that the sound IC/Board of the TV is defective and needs to be replaced.
If you want to replace the defective sound IC/Board yourself, please let me know so that I may direct you further.
Regards.
Posted on May 23, 2011
  • Walesarumi
    Walesarumi May 23, 2011
    In other words, there is nothing wrong with the sound IC/chip. Do you use a local antenna with the TV or are you using a cable receiver/decoder?
I have an RCA Tablet RCT6773W22 Android Version 4.4.2 The tablet is in Silent Mode.
I'm betting the volume switch is actually stuck and that the sound is just going down to "silent" the moment you release the "up" button. Does the sound get loud and just fade away? If so then that's probably it.
Feb 20, 2017 | RCA CA 7" Tablet with 4GB eory 28458515
Why do my Bose MB4s fade out when cranked up
There are many issues that can cause this. It could be a Power Supply, Amplifier, or scores of other issues. All these units have a microprocessor(computer inside the Bose unit) and are generally controlled with a Rotary Encoder( basically a volume control), or buttons. There are just too many problems that can cause this same issue; dead or won't switch or with indicators blinking.
If you're interested in repairing your unit, please visit my website at audioserviceclinic.com. Thank you.
Oct 10, 2014 | Bose Mb4 Panaray Bass Speaker/subwoofer...
My tv picture is faded and dark
you might need a new bulb, bulbs average around 4000 hours, depending on the bulb, they range from 750-6000 hours
Apr 20, 2014 | Philips 60PP9352 60" Rear Projection...
Volume fades out then may come back on-Proscan TV Model#PS35690LW
hello,
this will require you opening the back cover of the television.
Check for dry soldering and re solder in the audio section of the printed circuit board....
Good luck...
May 24, 2010 | Televison & Video
Randomly my volume is as loud as it can get no matter what. Whether the volume is on 1 or 60 it is blaring. Turning the volume to zero is still muted...anything I can do to fix this problem?
I turned my television off and unplugged it for a few hours and when I plugged it back in and turned it on... the volume worked like normal again. Woo
Nov 18, 2009 | Durabrand DWT2704 TV
Radio continues to fade in and out, plays for awhile fades out
Need more information on this if possible.
It may be the speed volume is enabled on your radio, does it fade out when you start to come to a stop? Some vehicles have a speed volume setting in their radios in which the radio raises and lowers the volume during driving conditions, like when your comming to a stop, the volume will automatically lower and during faster driving speeds will rise to a higher volume.
Hope this helps
JD
Sep 10, 2009 | 2001 BMW 325
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
Volume Control
How do you have it hooked up to speakers (are you using a center channel)? What listening mode are you in (dolby digital, stereo, pro-logic...)? It sounds as though you're not getting center channel info....
Jan 09, 2008 | Onkyo TX-SR605 Receiver
Extreme White Glowing
Your CRT fluid needs to be replaced. Goto www.TvRepairKits.com and order their fluid kit.
Sep 28, 2007 | Philips 60PP9363 60" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
