Question about Fisher and Paykel GWL11 Top Load Washer
My washer began leaking last week each time I use it. I have checked all the connections, made sure all lines in and out are free from debris. Any suggestions? It sounds to me like the machine is louder so I am worried it is the seal on the pump. I have heard this washer has that issue.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Try this on your machine.Power up the machine then advance the cycle to spin.Now push the start button.Does the noise start as soon as you push the start button or when the machine turns the bowl for the spin?Is the noise a rumbling noise or high pitched squeal?If the noise starts as soon as you push the start button the fault is your pump.If the noise starts when the machine spins the bowl then the problem is with the bearings and seals.Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on May 24, 2011
My ABS light came on last month ,3 weeks ago pedal went to floor,than week ago ,than last night . fluid an pads are good
Master Cylinder is leaking past its seals. As for abs, could be related or separate issue.
Jul 27, 2015 | 2001 Chevrolet Malibu
Im not getting enough water when washing clothes. sometimes if im washing heavy clothes, like sweatshirts, they come out and I can see dry spots on the clothes where water hasnt saturated them. also, when...
Hello
The problem may be the drain line.Unplug washer and remove drain line.Inspect line for any debri or lint.Check drain line screen for anyhting cloging it.
Be sure to tiighten all clamps when putting drainline back on.
Check incoming water screens.These are on washer where water hoses connect,clean if needed.
Last,try a self clean of machine.This sounds like a high eff washer which should have a cleaning mode.
Sep 23, 2011 | Washing Machines
Recently had a sediment problem with our well, is there another place to clean out sediment other than the screens at the hot & cold water hose connections on a whirlpool duet washer?
Hi and welcome to FixYa,
1. Drain and Flush your HOT water heater. This bugger will keep supplying sediment for weeks!
2. There can be hose screens installed at the wall connection also. Remove the hoses and check for hose screens.
3. Check the Inlet screens again.
4. Of you have a pressure tank.. Drain and purge (another source of debris)
Other than that as far a water supply those are the only places to be concerned about. Once your sure you have clean water.... re-check you inlet and hose screens once a week for a while as sediment will migrate through plumbing for extended periods depending on the type of sediment.
The screens can repeatedly clog for some time due to sediment.
If you experience a symptom that your machine will fill when off or leak water by constantly the debris has blocked open the inlet water valve needle at the diaphragm.
- You can sometimes back flush this by first removing BOTH inlet water screens from the water valve and reconnecting the hoses.
- Only connect ONE hose to the wall and turn on the water to the connected hose while placing the other hose in a bucket.
- Select WARM wash and let water flow into bucket. Tap the hose connections with the HANDLE of a hammer or screwdriver in an attempt to loosen debris.
- Reverse hose connections and repeat.
RE-install the inlet screens in the water valve and return the machine to normal use.
Thanks for choosing FixYa,
Kelly
Jan 22, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Problem with whirlpool duet washer
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer SUD F-02 problem: Recently I noticed that the water was not draining inside the washer once in a while. Starting last week, I heard the beep sound and it told me it is F-02. After...
May 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My 4870 K Boss is 2 years old. I have replaced belts & filters in the specified intervals. This last time I replaced the belt after a year, it shredded 3 of them on the outside edge of the belt in...
The only reason why it would be shredding the belt is if the pulleys were not lined up correctly. Check the allignement of the belt to make sure there is nothing kepping the pulleys from being in line. The other thing that it could be is if the roller was not rolling freely check the beater bar and make sure it is free and if not clean the inside of the end caps to be sure they are free of hair and other debris.
Feb 06, 2010 | Vacuums
Waste line leaking
handle is not in filter position turn off pump move handle to different position several time make sure that no debris under handel
May 28, 2009 | Hayward SAND FILTER, PRO SERIES
My washer began a grinding noise & says
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&$%^
Apr 19, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore he2 front load washer
“F21” (AKA SD) is a Long (SLOW) Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Apr 03, 2009 | Kenmore HE2 Plus Front Load Washer
Water doesn't pump out and F21 comes on display. Washer 2yrs old
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Mar 29, 2009 | Kenmore Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
65 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
