Question about Eagle Intellimap 502c iGps Chartplotter GPS Receiver
Eagle Intellimap 502c iGps No display backlight, common problem? Bjorn, Norway
  • bjoerikb May 23, 2011
    Thanks.
    Have you any idea of sources for schematic diagram?
    Bjorn Norway
    Will work with the suggestions
    Bjorn Norway
  • Eagle Master
  • 6,993 Answers
yes, it is a common problem with this unit. The display inverter is the cause of this problem. The display inverter has become defective that's why there is no back-display.
You cannot fix this problem with DIY because the parts (display inverter) for this unit are scarce.
I would suggest you take it to a local repairman within your vicinity as the repairman can replace the defective part inverter with a scrap or a bad unit.
I hope you understand the above.
Regards.
Posted on May 23, 2011
  • Walesarumi
    Walesarumi May 23, 2011
    Unfortunately, I don't have idea of source(s) for the schematic diagram or service manual. I'm sorry....
Lot of interference with unit transducer mounted on trolling motor when trolling motor is being used. Then clears up when not used.
Some how you have Radio Interference conflicting with your unit. The RF as it is called, may be coming from the engine. Try to connect to an INDEPENDENT power supply for the Eagle and not the same source your trolling motor. You seem to be getting line interference.
Feb 02, 2015 | Eagle Fishelite 502c Igps Fish Finder...
The Eagle 640c will not show the second Menu any ideas
try whats called a "soft start reboot"it worked for same prob on my one. with unit turned off hold down pages and power keys until it starts up and map of usa appears,release keys. you wont lose any waypoints or data but youll have to reset units of measure etc.
Dec 23, 2010 | Eagle Intellimap 640c Marine GPS GPS...
My Eagle 642C iGPS does not work with Lakemaster chip
If you do not have the most current software upgrade, that may be the problem. Go to www.eaglenav.com. If a more current software is available, download per their instructions. Worth a try. That unit should display LakeMaster digital chars.
Apr 04, 2010 | Eagle Industries FishElite 642C iGPS GPS...
The plug going into the back of my Eagle 350c got hot and partially melted. It still works now but for how long I don't know. Can I splice a new plug in or do I have to buy a whole new transducer?
Well, if it is still working ok now with the partially melted plug, then the transducer itself sounds like it is fine... Attach a new plug and it should all work the same (just with a nice new plug).
Also make sure your power supply to the Fish Finder is properly fused.
Feb 07, 2010 | Eagle Fishelite 502c Igps Fish Finder...
Machine does not acquire its GPS position. If it does it can take up to 45 mins to achive. Can I put an external antenna on it? The unit is used in an open boat, so has clear access to the sky, so should...
your antenna is probably original and obsolete see if you have a RayStar 120, if so, it is junk. The RayStar 125 is plug and play for you and sells around 300. Your GPS is a self contained receiver, that means it uses 12 V and output computer language. If you have no power to the seatalk antenna, you get nothing. If it is intermittent as you describe, 90% chanace it is the antenna, (mushroom or puck). 847-746-0100
Dec 28, 2009 | Eagle Seacharter 502c Df Igps T/M, Hst...
No back lighting and screen blinks. Purchased exactly 2 yrs ago
Sync lock transistor is faulty here. and i agree Lowrance units are unreliable and their service is soemthing else!
Aug 19, 2009 | Eagle SeaCharter 642C DF iGPS
Backlight flickers 2 years old to the date do you
Furuno has similar displays. I don't know if Eagle provides the same support but you may be able to find an actual schematic diagram technical manual from them if you ask nicely i don't know if Eagle has any government contracts but you can try and tell them you are with some government agency like DOD navy or coast guard or homeland security ;) and see if they will send you a PDF of the manual also try Retrevo.com they may have the techmanual on file. It sounds most likely like a connector problem between the LCD and the power supply. Does it only happen out on the water (vibration or shaking)?
Eagle Seacharter 642c back light flickers all the time
Mine did the same two weeks out of warranty and I was told by NAVICO, the Australian importer and repairer, to throw it in the bin as the whole unit would need replacing, thanks for the expert advice NAVICO. It will be the last Eagle/Lorance product I will ever buy.
Jun 19, 2009 | Eagle SeaCharter 642C DF iGPS
Marine GPS
change the antenna with new
Jan 12, 2008 | Eagle IntelliMap 500C GPS Receiver
Eagle Intellimap 502c iGps Chartplotter GPS Receiver Logo
291 people viewed this question
Top Eagle GPS Experts
fordexpert
Computer Links
carl blood sr
Are you an Eagle GPS Expert? Answer questions, earn points and help others
