Question about Vacuums
We have an E-Z -Go Power-Wise QE charger and the red led light flashes, which indicates a 'fault code' - What does that mean?
I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
not trying to be a smart a** but which of the two do you have?
1. A flashing blue light indicates that the battery is running low on charge.
2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
Best to you.
Feb 20, 2018 | Dyson Vacuums
My Dyson v6 animal vacuum won't charge
Hello. I have the same problem as Shelly. My Dyson will not charge. When removed form the charger the LED light flashes a few times and then stops. The motor does not run at all. When the machine is returned to the charger the same thing happens. LED light flashes , then stops! The power supply from the mains plug is live. Any ideas please? From Eleanor O'Neill.
Oct 04, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
Dc31 flashes green
Hi there, it's Jack at Dyson.
Usually if the indicator light flashes green when the trigger is pulled, this means the machine needs to be charged. If you have had your machine connected to the charger assembly for over 3.5 hours and continue to see the flashing green light, this could mean the machine isn't recharging correctly.
In order for us to diagnose which part is at fault we'd need to take you through some simple diagnostic checks when you have your machine to hand. You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Aug 03, 2014 | Dyson DC31 Bagless Handheld Vacuum
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I have an Energizer Model CHDC7 battery charger for AA/AAA batteries. I'm not sure how to use it. Specifically, when batteries are inserted and plugged in, it displays flashing green lights over all...
Nickel-Metal Hydride (NiMH) batteries are usually charged in pairs in consumer chargers. The CHDC7 can charge two or four batteries at a time. Their position in the charger is important (see the link at the end of this note). Each battery has a separate pair of green LEDs. There are no other LEDs on this charger. The LEDs light up to show the state of charge. Flashing means it is charging. Solid means it has reached that level of charge (ie, 1 LED = half charged, 2 LEDs = fully charged). The batteries will get warm but not uncomfortably so. After some practice you will be able to tell if they are getting too hot (which may signal a worn-out battery which should then be replaced). Like all rechargeable batteries, NiMH batteries have a finite life (measured in number of times they've been discharged and recharged). IMHO, they should also be used and charged in matched pairs. I mark them when I take them out of the box and keep them paired in use and in charging for maximum life. Yes, the devices that use 3 batteries are a pain to deal with. LOL. All details can be found on this Energiser data sheet: http://data.energizer.com/PDFs/chdc7_instructions_english.pdf
P.S. The CHDC7 remains open for charging. Closing it for storage is optional but minimizes the space it takes up.
Jul 30, 2011 | Vacuums
UNIT WILL ONLY RUN FOR FEW SECONDS THEN THE BOTTOM OF THE 3 LIGHTS WILL FLASH
I'm sorry to hear you're having difficulties with your DC16. A single flashing red light indicates that the battery needs to be recharged. When fully charged, all 3 LEDs should illuminate without flashing. However, if the red light continues to flash even after at least 3 hours recharging time, there may be a fault with the battery or charger assembly.
Please get in touch with us directly - one of our experts will be happy to run through some troubleshooting over the phone with you to determine whether the battery or the charger requires replacement. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Jul 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Our black and decker 14.4 Dustbuster is functioning but the charger does not shot its light that will indicate of charging. we dont know if the charger is not working or just the charge light is the one...
You can test the output of the charger with a multimeter. Set it at about the 20v scale and touch the contacts at point where it connects with the Dustbuster. If you get a reading it means that the charger is working. I would say that the charger is most likely not working because LED indicators very seldom fail while chargers are not all that reliable.
Jun 09, 2011 | Black & Decker Vacuums
Vacuums Logo
834 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
