Question about Makita Drills
Makita 8406 Core Gun. The motor inside is spinning but not spinning the chuck? Is this easy to fix?
  • 14 Answers
SOURCE: makita core drill model8406
Hi the 8406 was common for the intermediat gear to go have you yet stripped the gear box?
Quick test wear gloves to do this!
Turn on the drill if the chuck does not turn spin the chuck with a gloved hand TAKE CARE!! if the chuck catches grip one of the gears are gone.
Hope this helps let me know. Sean
Posted on Mar 04, 2008
  • 9 Answers
SOURCE: drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Posted on Dec 04, 2008
rowdy45176
  • 2176 Answers
SOURCE: makita 6408 drill motor. can't see how to replace the chuck.
If you have the 6408 as listed the spindle is threaded and you are correct there is no retaining screw. What you would need to do is find a bent handle allen wrench about the size of the chuck capacity 3/8" and insert the shorter end in the chuck and tighten. put the chuck on a block of wood or workbench and position the long end at about a 30 degree angle in the counter clockwise position and strike it with a hammer, this might take a couple hits. If this is not a 6408 let me know and I will look at the tool for you and see what you got.
Posted on Jan 23, 2009
  • 233 Answers
SOURCE: keyless chuck is stuck with bit inside
Try two channel lock pliers.
Hold the bit close the the base with one.
Take the other (cloth comes in handy here to prevent marring) and turn the chuck counter clockwise to release.
Alternative (little WD40 on the chuck)
One channel lock plier hold the chuck and put the drill in reverse.
The WD40 should allow the chuck to release easier.
Posted on Nov 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: I am looking for Motor part number 48973018
go to Makitatools.com and you can type in your model number and find and buy replacement parts online from the direct.
Posted on Dec 11, 2009
Makita core drill. I have the 8406 core drill and when drilling a hole today, the drill suddenly seemed to lose a lot of power, it turns but not delivering enough rpm's to have an effect on the brick! the...
Sounds like it got too hot and burned the motor up. Had this with a making grinder. They are a piece of junk anymore. Hope it's still unber warranty.
Dec 26, 2017 | Drills
Sds bit snapped in my makita bhr200 chuck.on taking the drill apart,the chuck is on a gear rod,and wont allow me to push the chuck down
You have to remove the striker bolt from inside the spindle first. to do this remove the internal circlip (not always easy) then you can tap the striker bolt out and then press the broken bit out.
Mar 15, 2013 | Makita Drills
How do you remove the clutch on a makita 8406 have split the body so far ..thanks
How is the clutch removed from the makita 8406 core drill
May 15, 2011 | Makita Drills
The chuck wont open or close properly the three bits inside dont work at the same time they are all different lengths
Hi, the simplest and best solution is to replace the whole chuck. This is a cheap and easy thing to do and suitable 13mm chucks are available online from lots of different manufacturers and are nearly all compatible. here is link to a genuine Makita replacement chuck , but there are plenty of cheaper brands to choose from. http://www.ereplacementparts.com/keyless-drill-chuck-p-90496.html Hope this was of use to you.
Jan 22, 2011 | Makita 6349DWDE 18V 1/2" MXT Driver -...
How to change a chuck on an 18 volt battery gun. makita 6347d
under the tip section or under my profile in the tip section is the procedure to remove the chuck. Let me know if you need help finding it.
Dec 20, 2009 | Makita Drills
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Broken Makita Drill 6408k chuck
separate the housing and remove the gear assembly and chuck ....see if you can use a open end wrench on the shaft and locking pliers on the chuck body
Sep 17, 2009 | Makita 6408K 3/8" Variable Speed,...
Damaged chuck
Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
May 14, 2009 | Makita 5/8" 2 Spd Hammer Drill
Makita core drill model8406
Dec 22, 2007 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
