Question about Viking VGSC366-6B Gas Kitchen Range
The oven door on my viking oven only opens half way. Model # VDSC365-4GSS
SOURCE: VDSC365-6B
ove corse you need to make sure your oven is or has cooled down and turn the breaker off for good measure  I had this problem.  I think the locking unit is jumping gears because i hear a grinding sound when Mine locks.  The way I got mine open was,  Lookalong the top of the oven door.  there are vent slits cut in the top, if you look in them where the latch is you will see the hook that is holding the door shut.  I took a butterknife ( you need something flat and strong because of the angle yu have to hold it at.  take the knife and push the hook to the left.  I will take a few tries but it should pop open.  once it is open and power is restored the latch will retract to its normal position.  hope this helps
Posted on Feb 16, 2008
SOURCE: VGSC3054 oven door won't open
After frantically calling Viking hdqtrs and several repair shops for their advice and experience, it turned out that after my husband fiddled further with it, something got unstuck and it miraculously opened all the way again. Don't think we'll ever know what caused it in the first place , but it works now.
Posted on Oct 12, 2008
  • 42 Answers
SOURCE: Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
Posted on Dec 21, 2008
Kgt1962
  • 59 Answers
SOURCE: Viking VGSC366 6B oven door won t open fully
Sounds as though the hinges are broken. Door will have to be removed and hinges replaced
Posted on Mar 08, 2009
SOURCE: Viking 36
The door can be removed from the hinge assembly by lifting upwards and outwards while the door is only slightly open - no hardware needs to be removed to get the door off. My door VGIC366 hinges did the same thing a few years ago, and simply cleaning them fixed the problem entirely.
Posted on Jul 30, 2009
MY 27 INCH VIKING PROFESSIONAL BUILT IN MICROWAVE OVEN ALLOWS ME TO SET THE TIME, BUT JUST COUNTS DOWN SILENTLY INSTEAD OF MICROWAVING WHEN PUSH START. CAN THIS BE REPAIRED? OR IS THERE A RESET?
Your bottom door switch is probably defective, or its mount is loose, misaligned, or broken.
This is usually caused by opening the door while it's cooking (instead of hitting "stop" first) or slamming the door.
See my help files on safety here, disassembly here, and door switches here.
More questions? Contact me directly here.*
* always include the full model number and FCC ID number from the label on / in your microwave (or a clear photo of the tag)
Jan 27, 2018 | Viking Microwave Ovens
Part numbers for door gaskets Viking double oven ved0530ss
Go to searspartsdirect.com with your model number. You'll find parts lists and diagrams there
Dec 01, 2017 | Viking Ovens
How can I fix or bay the one touch door open button?
This service manual shows the parts breakdown and the part numbers: Viking DMOC205SS Service Manual
Jun 18, 2014 | Viking DMOC205SS Microwave Oven
One of the doors (on the Viking french door fridge) opens too wide (180 degrees). I want to tighten it so it only opens slightly more than 90 degrees. The other door is fine. Thanks.
Check with your Viking rep. I have the same problem and got word from Viking they are coming up with a new hinge doorstop at different angles. It will come in a form of a kit. The one I'm getting is about 100 degree opening. The problem I had was the door was hitting and adjacent electric oven from Viking. It just swung too wide.
Oct 29, 2010 | Viking VCFF036 Bottom Freezer French Door...
How do you adjust the door swing angle on the Viking VCFF036 bottom freeze French door model? What are the angles?
Check with your Viking rep. I had a problem that the door swings too wide. They said they are coming u with a kit to replace the door stop. I was told there will be a 100 degree doorstop kit for my problem The door when swung open gets a ding from an adjacent Viking electric oven with the professional door.
Jan 01, 2010 | Viking VCFF036 Bottom Freezer French Door...
I have a viking VGIC365-6bss I pre-heated oven to 500 degrees and now the oven door will not open.
One of the door hinges was loose. You have to lift the door by the handle to open it.
Nov 26, 2009 | Viking VGIC365-6B Gas Kitchen Range
Wehre is model number located on viking oven?
It is usually on the stove at the bottom of the oven door. you might have to remove it to read it properly
Sep 18, 2009 | Viking Ovens
Jan 12, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking VGSC366-6B Gas Kitchen Range Logo
93 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
