Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
I have a five year old dryer, recently moved and changed to a 4 wire plug. It has correct voltage all the way to the machine but the display only has two faint red lines and all the lights that are on are only half lit. What could be wrong?
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on May 26, 2011
Samsung Dryer Issue
Is this Dryer in the US? It sounds like it may be as you are refering to a Phase Voltage of 120 volts and a Line Voltage of 240 v.
therefore it sounds like your machine is 3 Phase and in the past you have been wired as 3 Phase and Neutral (4 Pin), it could be that your 3 pin socket at the new location is only 3 Phase ( no Neural ) in which case you may have applied twice the voltage to the control circuit which should be only 120 volts in your case, check on the PCB of the control circuit for any fuse which may have operated, otherwise there may be power supply issues due to applying over voltage in the absence of a Neutral :-(
Feb 21, 2015 | Samsung DV218AEW Front Load Electric Dryer
How to connect a dryer
Hi Sheliah,
I'm an electrician and would like to help you. Assuming you're in the U.S. and this is an electric dryer (not gas), you will need to find a 240 (a.k.a. 250) volt / 30 amp circuit to connect it to for it to work. This would be connected to a double pole 30 amp circuit breaker in the electrical panel. There is no simple residential "adapter" to change voltage, current or number of wires - besides the old 3 wire grounding plug adapter in you grandmother's junk drawer. (What is a 50/250 volt dryer? - did you mean a 30A/250V?)
Your dryer should have a 4 wire cord with a 4 prong plug on the end - and it will need to be plugged into a matching outlet. The old electrical code allowed you to change the cord to match the outlet, but now it requires that both the cord and the outlet be a 4 wire type. The old 3 wire cord type is no longer permitted to be used when the dryer is moved or replaced. Of course, 3 wire cords are available everywhere and it is unlikely that anyone will turn you in for changing the dryer's 4 wire cord back to a 3 wire cord type (but I just wanted to tell they way it is supposed to be done). What you do - is your business.
If you have a gas (or LP) dryer, you probably only need a 120 volt / 15 or 20 amp outlet - they look like the standard types - but I think you'd have simply plugged it in and walked away if that were the case.
I hope this helped!
Apr 07, 2014 | Dryers
Bosch WFR2460 washer---we also had the matching AXXIS dryer until recently--it died. Replaced the dryer with a new LG. In old system, the washer plugged into the dryer via an outlet in the 220 box on the...
Hi joecci,
It looks like the Door Lock may be faulty, but here is a few things you should consider looking at first:
1) Is the door closed properly?
2) Have you tried giving it power straight from the mains, the door lock needs the correct power before it functions correctly?
I believe one of the above things will resolve the problem, let me know if it does?
Regards
JEDEMEYER1
Jul 11, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Dryer is 2 years old. Worked fine until we moved to a new house and could not hook it up. 1 year later I finally had the electric problem fixed and hooked the dryer up No Heat. Dryer turns on but NO Heat.
is the outlet 3 or 4 prongs?. voltage check the outlet for propper voltage. check connection at dryer power cord. 2 of the wires power the motor circuitry(120vac) the other 2 the heating element. you may have a loose connection in outlet,switch wires or bad-half trip breaker. if not,,,, there's a dryer problem, call us again with update please. good luck to you.
Feb 07, 2011 | Dryers
I am replacing a 3 prong cord with a 4 since we have moved into a newer newer home and the dryer has a white wire attached to the frame instead of a green wire. Is the the ground and can I just place the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 23, 2010 | Roper RES7646KQ Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
I moved into a house that has the 4 prong dryer receptacle and I bought the new 4 prong plug to hook up to my dryer but there are only 3 wires on my old one. The new one has a red, green, white and a black...
be careful the voltage may be different thats why they make them with different plug configurations. check your dryer voltage requirement. usually the four wire type are for 250vac electric dryers.
Mar 06, 2010 | Dryers
Brand new roper dryer, was working fine, moved it to a different house, had to change from 3 wire to 4 wire cord, now it runs but no heat. have 110 on black, 110 on red, all components ohm good
the wires may not be hooked up right. make sure the red goes to red, black to black, white to white.and the green one screwed to the groung screw.
i have had this problem where all the components check out good and the power was correct,and the unit would still not heat,the end problem was the wiring from the main breaker box was incorrect and not carrying enough current to operate the machine properly.you may have to have the wiring check for proper current flow.the voltage maybe good but the amps and current may not be porper.
if you have a electric stove with the same kind of cord you can move the range out and plug your dryer in there just to check the operation of the dryer.
Jan 26, 2010 | Roper RES7646KQ Electric Dryer
I need to change the 3 wire plug on my whirlpool model LE5790XS dryer to a 4 wire plug...old one is not color coded and I dont want to hook it up wrong...whats the correct way to connect this plug?
To install your 4 wire plug ,the white wire goes to the center wiring terminal on the dryer. The green ground wire attaches to the terminal cover screw outside the dryer. The red and black wires go right and left on the dryer terminal.
Nov 12, 2009 | Dryers
Dryer won't start
check to ensure you have voltage at the outlet
the four wire pattern goes like this
black far right
red far right
white in the middle
geen to the chasis
Oct 01, 2009 | Maytag Dryers
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
