Question about Marantz PMD620 MP3 Player
When I press record, it says Err Card 1. I've tried a new card and formatting. Any ideas?
Sorry to say that it's clear that this Marantz recorders develop this problem over time and Marantz has offered no solutions. When I first purchased this recorder it was enormously reliable and stable, but I find now that it is totally the opposite -- often it has recorded for a while and then suddenly develops an inability to read the SD card and so either quits recording or freezes up.
There seems to be no clear solution to this, and the random nature of the problem makes the recorder wholly unreliable in a live or field setting. This is, sad to say, unacceptable.
Posted on Jul 27, 2011
Zoom H1 says
What format are you recording in? Recording in the standard resolution WAV format will only give you about 3 hours in total on the 2GB SD card that comes with the H1, whereas lower resolution WAV recording or MP3 recording will give you more hours, more than 34 hours form MP3 at 128kbps.
Mar 03, 2012 | Zoom Audio Players & Recorders
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
Oct 14, 2011 | Zoom H4 Handy Recorder
Hi, I'm having trouble with my marantz recorder. I've reached the 999 track limit, but despite deleting older tracks it still won't let me record. The solution must be something basic I've...
Since you have reached the 999 track limit, it is possible your CF card may have been corrupted.
On page 28 of your manual you should find the instructions for formatting your CF card.
"How to Format a CF Card."
This may get you going again.
Hope this helps.
Sep 14, 2011 | Marantz PMD660 Digital Voice Recorder
My Nikon D80 shows an ERR, what should I do? FYI...I tried turning the camra on, removing the battery and pressing the shutter button for 30 seconds. That didn't work.
It's possible that you need to format the memory card. Formatting is found in the camera set up menu scroll down to "Format Memory Card" and follow on screen instructions.
Formatting should be done after each time you download pictures to your computer. Not delete, as delete does leave some data behind and eventually clogs the memory card so new data can not be placed on it. Another possibility is that the card somehow has become locked I'll include a diagram. Also a new card needs to be formatted to the cameratri3mast_228.jpg it is going to be used in.
Diagram
Jan 27, 2011 | Nikon D80 Digital Camera with 18-135mm...
My recorder keeps coming up Card Full when I press record, but I have a new stick in it, please help ;)
Format the new card in the unit. Often the delivered format in a new card is not compatible.
Nov 29, 2010 | Boss Micro BR Digital Recorder
PMD620 won't recognize SD card
I'm using Sandisk 2gb SD card in my Marantz pMD 620. I've formatted the card but after 5 minutes of recording it stops says Err 8
Apr 05, 2009 | Marantz PMD620 MP3 Player
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Feb 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Rebel XT will not work with new faster CF cards.
Check the volume and speed of memcard, maybe it is not compatible. error 99 is an indication that a lens or shutter curtain is not working, so i cant see any connection with the memcard problem. Check your camera memcard compatibility.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Marantz PMD620 MP3 Player Logo
318 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
