Question about Epson CX3810 Stylus Color All-In-One Printer
Printing Question Can you please advise me on how or even if the CX3810 can print in just black and white? I do go to the advanced options on the print screen and change to black ink only and it still comes up that I'm out of ink on my color cartridges, thanks. Major Scott E. Dixon (USAF)
  • Anonymous Feb 23, 2009
    My ink cartridges also ran out. I replaced the black ink cartridge, but not the color cartridges because they were not actually empty (different issue). Once I replaced the black ink cartridge, I tried to print using "Black Ink Only" under the advanced settings without success. I really do not want to replace the color cartridges, especially since they are not actually empty. How do get the printer to print?
Are the epson ARC chipsets available on office depot or big retailers?
Posted on Aug 21, 2008
Will Epson Stylus CX3810 not print in black and white if just the cyan cartridge is empty?
The new printers will stop printing till the time you replace the empty cartridge with a new or filled cartridge.
Regards,
Shrey
May 30, 2011 | Epson Stylus CX3810 All-In-One InkJet...
I have a networked HP 3600n printer.\r\n when printing in grey scale it prints in reverse, so the black is the back ground and the writing is white. Can anyone please advise? The OS is XP and the server...
The "Mirror Image " printing option is enabled.
Click on START - Control Panel - Printers and Faxes. You will find list of Printers Installed
select the HP 3600n Printer icon and right click on it. Select Printing Preferences. Under Advanced Features you will find "Mirror Image" - Choose OFF and Click ok and Save the settings and try printing.
Jun 17, 2010 | HP LaserJet 3600n Printer
Print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
Apr 07, 2010 | HP Deskjet 3845 InkJet Printer
Would a CX3810 work with only 1 black ink cartridge?
all epson type need all catridge put in a head, if you want use black only, you can buy ciss sistem
Dec 23, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Printing in ONLY black & white
go in to the printer settings,click advanced settings,there will a option to print in greyscale
Nov 28, 2009 | HP Photosmart C3180 All-In-One InkJet...
I just want to print in black and white. How can I change the settings?
When you try to print, go to the advanced options. There in one of the tab you get the option of printing in either black and white or grayscale. Use that option to just print the page in black and white.
Nov 19, 2009 | Epson Stylus Color 860 InkJet Printer
Can't print color only black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
May 18, 2009 | Dell 966 All-In-One InkJet Printer
Dell Photo 944 won't print black and white
I had the same problem and just figured it out! On your control panel, choose printer and then Properties. Go to Printing Preferences and click on the Advanced tab. Under this tab is a button for More Options and then a section Complete-A-Print. I had to uncheck "use color cartridge for all black printing" and then check "use black cartridge to print in black and white." Then I had the option back to print in black and white. I have a Dell Photo 964 but I'm assuming the options should be the same. Hope this helps someone!
Mar 08, 2009 | Dell 962 Photo All-In-One InkJet Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Jan 12, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Epson CX3810 Stylus Color All-In-One Printer Logo
123 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
