Question about Timex Watches
I just replaced the battery on my Timex WR100 watch, but can't seem to reset it correctly. There is a sticker on the original battery "AFTER BATTERY INSERTION SHORT AC PAD AND BATTERY (+) TO RESET" I can see a small letter "A" partially underneath the area that the sticker arrow points to, but after several tries with a paper clip to short to the + side of the battery, the display is still blank. Am I doing something wrong, or is this watch just dead, dead? Thanks Byron S.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 125 Answers
It sounds like you're not far off. Peel the sticker back a little, and see if there is a small contact point (usually yellow metal) - this should be marked 'AC'. Short this to the + for 3 seconds, then repeat for good measure. If that doesn't sort it, try taking the battery out, wait about 30 seconds then put it back in and reset if necessary. If there's still no display, obtain a known working battery and try again.
If you still have no display, it's time to give up and admit it's dead.... unless you've been using a plastic coated paper clip.
Good luck.
Posted on Sep 07, 2017
4 Suggested Answers
SOURCE: Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...6e1fe0e.jpg
Posted on Jul 06, 2008
SOURCE: I have just replaced the
To all who need to change their Timex Ironman Triathlon watches:
It is a little confusing, but this is a watch you can change the battery by yourself!
First you will need:
-A big clear area (i.e. a table or counter) with lots of light to see what exactly you are doing.
-Small screw driver (like the tiny ones for a glasses care kit)
-Paper clip
Directions:
1. Remove all screws from the the back of the watch (there should be 4). Make sure that you take note of which screws are coming from which spot on your watch and keep them separated as such.
2. Next, you should see a white circular sticker with directions on how to change your battery. They aren't clear as "how to" but they are the basics.
2a. Take off the white sticker once you have memorized the places it is pointing to; set it up as such in front of you so you can refer back to it from time to time.
2b. You should see two silver pieces. One should be a circle (which is the battery), which is held in by another silver piece. This unlatches. In order to do so, you need to simply pop it open on one of the sides (as it tells you in the directions). You may use the same screwdriver or even a paper clip works wonders!
3. Replace your battery (should be CR2016) with the + on top, facing towards you. make sure it is flat, not just shoved back where the old battery was. This make take some extra time and patience to make sure it is done right.
4. Snap the silver part back into place (should look like it is holding the battery in place i.e. a gate).
5. THEN: this is the most important and confusing part in my opinion. On the white sticker the directions read: "after battery insertion, short pads to reset". this should look something like an oval with a line cutting it in half (vertically). It is not on the battery but next to it. You will need the paper clip here to hold down the right most side (at somewhat of an angle). this should do it! you'll know if your digital faces flashes numbers at you and may even light up. Make sure you hold down long enough.
6. Once you have the numbers flashing, you are good to go. Put the back of your watch back on, taking note of which screw goes where. Then, set your watch accordingly and you have just changed your watch! Ta-da!
Follow these steps and you should be good. Good luck to all!
Posted on Apr 22, 2009
escapement
  • 2334 Answers
SOURCE: I'm trying to restart a
Make, model, all numbers, please.
Posted on Apr 03, 2011
How does one replace the battery used to power timex rush T44361
Hi Debra, yours might be similar to my IronMan watch...... 4 small Philips head screws to remove then back comes away to reveal a sticker that has 2 clips either side, use a safety pin point to release the clips and the battery comes off with the sticker! The battery is placed with the total flat side upwards! Hope this helps!
Nov 01, 2014 | Timex Indiglo Watches
Hello. I own a 40 to 50 year old "Timex Electronic" watch. There is a number date at the 3 o'clock position. I see no other identifying info on the outside. I don't have a battery for it. How
What is the exact model of the watch. I have several Timex Electronic watches that might fit your description. If you pop the caseback do you see the old battery inside? Most batteries would have a reference like: CR2016.
Jan 06, 2013 | Timex Watches
Replaced battery but unable to reset watch to correct time, etc??? says on sticker on back of battery, "short pads to reset" short what pads??
there is reset button beside the battery or you have another option is to push all the buttons of your watch to reset and you can now set the time, date and other that had to be set manually..
Jul 08, 2011 | Watches
How to set the time and calender in wr100
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Sep 02, 2010 | Timex 2G561 100 Meter Watch
How can I reset the "short AC pad and battery (+) on timex expedition
You know where AC pads are right? If you don't know, look at the sticker. there is an arrow on the sticker. An arrow points out 11'oclock.
After insert the bettery, you just touch the golden pads with metal screw. that is how to short AC pads.
Oct 13, 2009 | Timex Digital Expedition watch
I have a Timex Indiglo watch that I had replaced the battery. I used the correct battery CR2016 and the watch doesn't work. I have replaced batteries in watches many times and always have had the watch...
This watch will have what is called and "AC" or All clear to reset it. There should be a white sticker with very small print on the back lid that will walk you through doing this procedure. It typically involves pressing down a tiny lever onto a small metal pad that will reset the watch.
Sep 15, 2009 | Timex Watches
NEW BATTERY. NO CHIME OR BEEPS ON THE HOUR,TIMMER, AND ALARM WHAT CAN I DO TO FIX THIS PROBLEM
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry2.gif & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: info@goamfix.com
web: www.goamfix.com
Sep 14, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
May 31, 2008 | Timex Advanced Data Link 53722 Wrist Watch
Resetting Watch
Here's the inside of my Timex Expedition Dive watch. To reset the watch after replacing the battery, press down with a small screw driver on the metal tab that the red arrow is pointing to.
Nov 20, 2007 | Timex Expedition 84601 Wristwatch
Watches Logo
79 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
