Question about Aquabot In - Ground Robotic Pool Cleaner
My Aquabot seems to have lost power...it moves along but can't climb up the sides. It doesn't seem to be vacuuming anymore either and is not expelling water through the top.
  • 1 more comment
  • Anne Jefferson May 23, 2011
    Thanks, I agree it sounds like the motor...problem is I can't find anybody who services Aquabots, at least not in my neck of the woods.
    Will do, thanks.
    Yes, this solution confirmed my thoughts on the problem. Thankyou.
  • 670 Answers
I think you have a bad motor it would be better to have it checked on one of their centers or by a local technician to check if it has a serious problem or if it just needs some cleaning.
Posted on May 23, 2011
  • Marlon Deza
    Marlon Deza May 23, 2011
    Well that's the only possible reason I could think of why its not capable of climbing up the walls and pumping the water out.
    I have checked at aquabot's website and you may want to give a ring to some phone numbers in there so that they can probably service the pool cleaner for you.
    try checking this link:
    http://www.aquabots.com/index.htm
    Thanks a lot!
My aquabot keeps trying to come out of the pool
Aquabots are interesting little robots! They're made to clean the entire surface of the bottom of the pool, and in regards to cleaning the sides, they are programed to climb walls, but once they reach the surface the programming recognizes the specific angle of the top and sends it back down the wall. Normally an Aquabot should never leave the pool. It should reach the surface and go back down the wall to continue cleaning. Good luck!
Pool Remodeling in Clearwater FL
Jul 17, 2014 | Aquabot In - Ground Robotic Pool Cleaner
Tip
Helpful exercise for you
In summer time time, what outdoors activities you'll like associated with your friends? How about hold a competitive sport of hill climb racing, or register a tournament of moto racing? If you feel tired and hot, you may even invite your friends to sign up the applying name dr driving, the bet on driving cars around the telephone.
Becoming an outdoors sport activities, climbing gets the best factors on our bodies. This is an fitness, and consists of the constituents of weight lifting, According to their physical strength and physical fitness, the amount of exercise, exercise intensity might be modified, It might be mentioned that climbing can be a more comprehensive fitness effect and ti can be a relatively small , dangerous exercise. And prior to deciding to climb the hill, you may carry out some warm-up. A little bit of muscle stretches to relax the muscles, when you climbing you'll feel a good deal simpler. You may also Increase bounce action. In the event you adding bounce action every single step if you climbing, not solve these questions . save energy, however the spirit you'll fell appear energetic. Then when you prepare to climb, you may ready to involve some products like maps, water, food, shades and so on.
Participating a moto racing seems dangerous, but it is a terrific way to release your pressure. However, it might enhance people's friendship. Dr. Driving is certainly an ultra-realistic 3d vehicle racing game.
This is often a fascinating action arcade racing game. This racing game's finest feature could it be simulates the particular driving for instance hanging profile. Blindly throttle will rapidly be surpassed with the competitors. Wining prize money enables you to buy a new vehicle, the automobile could also be used to upgrade equipment.
Lots of activities that can be done along with your buddies, why not select one to sign up?
on Aug 15, 2016 | BISSELL 12Amp Healthy Home Vacuum
Freezer too warm
First off, how old is the unit? Without knowing, my advice, and what has worked many times, is to unplug the unit, and turn it upside down. Thats right. Upside down. May take a couple or few people, depending on the weight. What this does, is to have the refrigerant begin running back to the top of the unit. Sometimes it settles in the bottom, and has to have extra help to start moving properly again. If, after about 6 to 24 hours it doesn't seem to have helped, it could be that you have lost the fluid, but that doesn't seem very likely. If you had, it would run consistently at the same warm temperature. If it helps, you may want to repeat the procedure to insure that it is completely free flowing. Cheap fix, if it fixes things. Good luck.
Nov 15, 2012 | GE Monogram ZFSB23DRSS 36" Monogram...
Will not clean shallow end of pool heads directly to deep end
Make sure that the Floating Handle is locked diagonally across the top of your Aquabot's body.
Clean the Filter Bag thoroughly so that the fine particles of dirt that get trapped within the fibers of the
Filter Bag are removed. To test if the Filter Bag is inhibiting the
Aquabot's performance simply remove the Filter Bag and operate the cleaner without it. If the Aquabot then pumps
water strongly, and climbs the walls properly, the Bag most likely requires a thorough cleaning
Sep 12, 2011 | Aquabot In - Ground Robotic Pool Cleaner
Aquabot Turbo T2 flips over when it tries to climb walls. Water is not coming out the top but the unit is moving fine. Does it need a new pump motor or can something just be clogged inside??
the likely problem is the float/handle. Make sure it moves freely and is always in the straight up position when on the bottom of the pool. If it's not then it is the problem.
Jul 20, 2011 | Aquabot Turbo T
Aquabot wont pump or move, intermmittent
Well either you have a jammed up motor, or a bad motor, or the Controller unit has faulted.
http://www.robotshop.ca/PDF/aquabot-turbo-t2-manual.pdf
Above is a manual, this should help you it has exploded diagrams to help. There seem to be many ways that it could get tangled up, or maybe the belt has come off, any way it's about time to A: Get a screwdriver, or B: Call a service man....
Jun 01, 2010 | Aquabot Aquaproducts Automatic Swimming...
Our aquabot tips over and of course cannot run
Try the ideas given at the website: http://www.i-love-my-aquabot-automatic-pool-cleaner.com/
Shelby Christian dansker01@msn.com
Aug 04, 2009 | Aquabot In - Ground Robotic Pool Cleaner
Aquabot Turbo T won't climb
1.`. Replace your old, water logged floats. They will dry out when the unit is out of the pool, and the unit will work fine until they water log again, which may takes as few as 10 minutes in the pool. 2. Stop using all those words *********** didn't teach you and probably didn't even know...This is a common problem. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/ gives some really good insight, too! S. Christian dansker01@msn.com.
May 11, 2009 | Aquabot Turbo T
Aquabot T2 moving in circle
The T2 has one set of belts and a single drive motor. Since one side must be rotating to be moving in a circle, we can then assume that the motor and belts are not the issue here. The two halves of the brushes are connected by a mechanism that allows them to turn independently of the other half. They can rotate about 3 times before they “lock” and act as it were one (not split) brush. This “slippage” is how the cleaner turns. Make sure that they do lock by manually rotating one side. If not, you will need new brush/wheel tubes.
A parts diagram can be found here:
Aquabot Parts and Repair
Jan 09, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot In - Ground Robotic Pool Cleaner Logo
304 people viewed this question
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
