Question about Samsung LA22A450 22 in. LCD TV
Hi samsung support team I connected my LCD-TV (LA22A450C1) by HDMI cable to a Nvidia GTX570 card. when I open any 3D application I have a massive flicker in my screen till I turn my TV off & then Turn it back on. it happens after closing applications too. what should i do. is any update or firmware for this problem?
  • 395 Answers
SOURCE: Samsung LN-R408D - No Picture
reseat the LVDS cable inside the unit. this is the cable from the main board to the panel. if the problem is still there then replace the main board 1st, part # BN94-00629F. if the problem is still there then the panel is bad, part # BN07-00245A. if you are not familar with TV repair have a tech repair this for you, if it is under warranty call the manufacturer for nearest repair place.
Posted on Feb 26, 2008
  • 29 Answers
SOURCE: Samsung LCD TV shut off, wont turn back on...?
power supply probably went out
Posted on Mar 15, 2008
ginko
  • 19396 Answers
SOURCE: Samsung 40" lcd - Connecting to PC saying 'MODE NOT SUPPORTED'
First of all, check that the TV is set on PC input when you use PC video input at the back.
Then you may also need to go to video and display properties>>settings, from control panel (personalize on Vista).
There lower down resolution and ensure that frequency is set the same as tv.
Posted on Jan 02, 2009
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
Samsung lcd tv la22a450c1 service menu code
If you wish to get some details; check the site linked here. Pull up older posts.,,,
http://electro-medical.blogspot.com/
May 30, 2016 | Samsung Televison & Video
Cannot connect the laptop to the tv
Hi Andrew.
The only way to connect your laptop to you TV is with a HDMI cable. If your laptop don't have a HDMI connector, you cannot do it. HERE is a picture of a HDMI connector.
Sep 13, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
My tv hdmi ports connedts to only lg products now i was able to connect my playstation to my lg tv and watch 3d movies but last couple days tv says connecting and no signal playstation works with hdmi...
Dirty Connections Dust plays Havok with those connectors go to Radio Shack and pick up a Can of Contact Cleaner Spay both the Jacks and The cables
Dec 30, 2011 | LG 55 55LW5600 3D LCD TV
Can I use a Samsung 3D blu ray player with a 3D Sharp TV
In theory it should work but there are some know compatibility problems with HDMI connections mainly on older equipment so it is usualy better to use equipment from the same manufacturer. Key points are to make sure you have the latest firmware update installed in your blu-ray player (& TV if you have the option to do it.). Second issue is to make sure you use a suitable HDMI cable. It must be at least a "High Speed" HDMI cable. Sometimes labeled HDMI 1.3 or 1.4. I use 1.4 version cables purchased online from Cables UK . Dont spend a fortune on expensive cables from currys/comet etc. they are a massive con.(digital signals dont need expensive cables).
Nov 27, 2011 | Televison & Video
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
When i plug in the HDMI from the computer, WIndows Vista system NVIDIA graphics card, I get no sound. When i plug in the BlueRay player, i get sound just fine. This computer outputs to my samsung TV just...
You are using different type of HDMI cables
OR
you should use different type of HDMI cables ,depending on the products you want to connect. There are 5 different types.
Maybe this link can help in defining which cable type you need exactly.
http://www.hdmi.org/consumer/how_to_connect.aspx
Sep 19, 2010 | Philips 26PF9966 26 in. LCD Television
Hdmi
Hi, =)
Basically what you need is to connect the S/PDIF out from the soundcard\motherboard I/O ports to the 8500 graphics card S/PDIF in and HDMI should now carry both video and audio.
So you have to check the video card. On the top part you'll see a white plastic with 2 pins inside of it. This is the connector SPDIF input from the video card. So what you have to do is look up in your motherboard for a connector with 3 pins that says SPDIF OUT. Even though it looks with 3 pins ONLY 2 of them are needed. You will basically need ONLY a cable like this:
http://www.tigerdirect.com/applications/Se...00&CatId=69
You can get it at a local pc technician shop for 2 bucks only.
Anyway what you do is connect one end of the cable to the two pins from the white connector from the video card and the other end of the cable to your motherboard on the first 2 pins of the SPIDF OUT connector. Now the way to know which ones are the first two, do it this way: The first two considering reading SPIDF OUT meaning that the first one is the one closest to the "S" letter of SPDIF OUT.
If it does not work trying connecting the cable differentely as you might be connecting in a reverse order (positive-negative). Don't worry about burning anything as it's only a sound cable, and it does not carry any power.
Once you do it, go to windows control panel and select SPDIF as your default sound playback.
And you're ready to enjoy sound and video thru HDMI now!
Aug 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Set Up PC to TV
What type of video card does your pc have??? if it is an nvidia card, you have to go to the control panel and set up for dual monitor..when you connect your laptop to an external monitor, you have to press control and f8 keys for couple of times ...that adjust the color to 256. Are you doing that?
Let me know
Apr 10, 2009 | Sony Vaio FZ31M Notebook
Samsung LA22A450 22 in. LCD TV Logo
144 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
