Question about Marantz SR5005 Receiver
I have a Marantz 5005, and the front left speaker sound level is much lower than the right one... however both of them are with the same sound level... I ve already changed the speaker but the problem continue..
  • boturao May 23, 2011
    The sound is much lower only on the left speaker, the right and center are ok.... the individual level is the same as for the right one...
  • Anonymous Mar 12, 2014
    Marantz 5005, Video and BD outputs not allowing picture to be on TV. Sound is good, just no picture.
    Brigadier General:
  • 8,546 Answers
Have you looked at the manual?
Each channel has individual calibrations settings for loudness and distance (delay). Start with that.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR5005-Receivers-manual/id/23730ci554/t/2/
Posted on May 23, 2011
    I´ve already did that, and the receiver was working perfectly a couple of days ago... I think something must have disarmed that specific output, is this possible??
  • David Dunn
    David Dunn May 23, 2011
    Disarmed versus lower in level? Is it silent or lower? Front speakers are defined as a pair. So does the individual speaker level adjustment affect it at all? BTW: If there is a plus setting for the fronts I'd advise against using it. Something has to be the stake in the ground (zero reference).
MARANTZ sr5200 Left Speaker larger sound right speaker
If you are saying that the left side is LOUDER than the right it could be DC offset on the recording or it could be phasing issues.
Feb 15, 2017 | Marantz Audio Players & Recorders
How to set up my speakers
You may have configured your Marantz to use only left and right front speakers.
Apr 25, 2014 | Marantz SR4002
HI, I have Receiver Marrantz SR- 5005, the center chanel does not work, please tell me what happened and solution to fix the problem. Thanks
Get the manual and open it up to the part where speakers are defined, then test it/them with tones. Try swapping a different speaker into the center if the current center channel speaker still doesn't work.
Web search "Marantz SR-5005 manual" (note the spelling)
Aug 07, 2011 | Audio Players & Recorders
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
I have a Marantz PM6010SE K1 signature amp - just for listening to CDs, if anyone remembers them. The amp creates a low level (mains) buzz in the left speaker. If I turn up the volume to max the low...
Use on the control buttons and other switches balance contact spray as the first step let it work for a few minutes.
Control the print for some loose components (solderings) by carefully some manipulation and movement on print and components with a wooden or plastic object, because solderings on active heat-conducting components have allways high priority on the end stage, and in power supply primary you can become early loose components in the solderings if the manufacturer has used leadfree solder. If you have after this no improvement then ALLWAYS refer the damaged to find components replace always twice (on both sides) each other replace if a damaged deformed capacitor or diode was found both as well left as right the same brand components , be carefull in replacements its very important because of in most repairs refurbishing for tonal influences Passive components as example (only suggestion) to take a capacitor 10Volt 330 MF then replace it for a 16 volt 330 mf the size should in most case be the same of the component its very important for tonal effects and balance, in most repairs is that more size format on capacity sounds better as the new order components become smaller on the same voltage its better to get the higher voltage capacitors with the same size as the old lower voltage ones.
http://akdatabase.org/AKview/albums/userpics/.../Marantz%20PM6010F%20Service.pdf
Jun 27, 2017 | Marantz Audio Players & Recorders
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
1. Sub should be on about your knee level or below,
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 06, 2010 | Logitech X-530 Computer Speakers
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
Polk Audio RC55i In-Wall Surround Speakers (can't hear whispers)
I'd make sure that the receiver surround mode is set for one of the digital settings, such as Dolby Digital or DTS, and make sure that you have the center channel level adjusted to a level similar to the other two front channel speakers. I've seen/heard this happening when using dolby digital material & having surround set on something like 'hall' or 'stadium' or dolby surround, where only 4 channels are used & the amp has to 'mix' sounds to the left & right front speakers. It'll often sound like the actors on screen are talking out of the bottom of a barrel, with a hollow & tinny character to the voices.
Jan 07, 2008 | Polk Audio RC55i Main / Stereo Speaker
Marantz SR5005 Receiver Logo
254 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
