Question about Smith Corona Wordsmith 200 Typewriter
The XL 1700 typwriter lock light is blinking and I can't type. Any ideas?
DSI XL won't power on, but orange charge light is solid (doesn't blink) when charging.
dsi xl getting wrong voltage at plug that goes to the battery. I have 5.78 from charger at battery connections I have 5.78,3.87,0.45,1.98 it bounces all over any ideas?
Jan 25, 2013 | Nintendo DSi XL Console
Blinking auto lock Whirlpool
What does it say in fine print right under control lock? "Press & Hold"? Page 16 of the user manual shows it as "air dry" with two lights, twelve and three o'clock positions. It says hold it for four seconds and the light turns off.
Aug 20, 2012 | Whirlpool GU1200XTLS Stainless Steel...
Xl1500 won't type lock light flashes
Try poping off the shift and shift lock key tops to see if the springsb are damaged or sticking down.
DickyO
Aug 01, 2012 | Smith Corona Typewriter XL1500 Refurbished...
My turn signals light up but do not flash, any ideas?
when the turn signal's are on my 1976 125 XL Honda and blinking ,and if the tail light is on it blinks also and the light on the speedo . if you turn the light switch off then then don,t blink just the signal light that are suppose to blink
Apr 15, 2012 | 2007 Qlink Axon 50
Training manual for maxxus
I have found many manuals just by checking online, i.e. "maxxus trainer manual", and see what pops up. You'd be surprised. If that doesn't work, contact the dealer.
Feb 05, 2012 | Concept Bayou Maxxus 1700 XL Total Body...
How to set clock on Sharp XL 1700 stereo
When the system is off take the remote and press the clock function. After the system lights up press and hold the memory button on the remote. Then press preset up or down to change hour (cycle through 12 hours to change AM PM). Then press the memory button again to change to minutes and repeat.
Jul 30, 2009 | Sharp XL-1700 CD Shelf System
Dell 1700
I've experienced this in the past and found a paper jam in the back feed roller and had to take the unit apart to retreave document. Try doing this (only if no longer under warranty) there are a few screws in the front and it should be able to come off easily.
Nov 10, 2008 | Dell 1710n Laser Printer
Sears typwriter
some typewriters have a carriage lock on the carriage to lock it in the center position, or it may have typet to the right margin which causes a typebar lock to activate untill you da a carriage return to the left side of the paper.
May 21, 2008 | Office Equipment & Supplies
Unlock
I the carrier free to move when the typwriter is turned off?
May 02, 2008 | Smith Corona Wordsmith 200 Typewriter
Smith Corona Wordsmith 200 Typewriter Logo
57 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
