Question about Lasko 3723 Floor / Box Fan
Lasko fan can u tell me how 2 take the blade off my fan? it stopped working and i wanted 2 put in on another fan that works but has a broken blade
    Problem Solver:
  • 5 Answers
I can tell you how to take the fan blades off your Lasko Model 3723 fan, but you might not be able to use it on your other fan. The reason why is that the motors, although similar, may not have the same diameter shaft.
Of course, you should have the power cord unplugged from the AC outlet before removing the front fan grille and placing your hands on the blades. Safety first!
The fan blades and hub are a single unit that stretches to fit onto the motor shaft. There is no setscrew at all. Take any sort of metal bar or tool such as a screwdriver or pry bar and carefully lever the hub off the shaft by pressing your lever to lift the hub a small fraction of an inch on each side, working the hub slowly upwards against the long vertical bars that support the motor. If you have reasonably strong hands, you may be able to pull the hub toward you by placing your fingertips under the edge of the hub and pressing with your thumbs against the vertical support bars as needed. It's not too difficult to do.
Posted on Jun 11, 2009
How do I take off to replace a lasko cyclone 3542 fan blade ?
Bex,
THose usually just pull off. You will have to pull hard because there is a spring clamp that they sometimes put around the inside hub of the fan. If there is a clamp, you will need to transfer that to the new blade. Hope this helps!
Jun 13, 2015 | Lasko Dryers
BROKEN BLADE
Replace Fan, order part from Lasko
Aug 03, 2008 | Lasko 2152C Hassock Floor / Box Fan
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
How does the "Ionizer" work on the Lasko 48" Wind Curve Tower Fan ? Shouldn't there be a HEPA filter to change or something to clean once in a while ??
I'm not exactly sure, but I think that an IONIZER has nothing more than metal blades inside that 'capture' dust/debris and contaminants from the air on the blades. There should be a handle to lift up on and remove the long blades.
You rinse the blades with warm soapy water, dry them and put them back in. Maybe I'm thinking of something else, but to me, that is what an ionizer is. Hope this helps at least some.
Best, Jennifer
Jul 08, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
My Lasko 40" tower has stopped blowing air - all other functions work as normal. Please advise.
Had the same problem with model 2551 - Lasko customer service said it was a failure of the electric motor that operates the blade unit. They do not sell replacement parts for their products, and if the unit is out of warranty (1 yr), your only resolution is to purchase another fan.
I disassembled my fan and discovered that the Decomin electric motor (#2033014) can be fairly easily replaced with a screwdriver and pair of pliers, but these motors are not for sale separately, even though they are still manufactured in China for Lasko and other product companies - they have their own website, but only sell fans, not parts.
May 22, 2010 | Lasko 2530 Elite WindTower Fan
My lasko fan stopped working after a power outage. the motor hums but blades dont spin
check the capacitor usually found beside the motor winding or inside the switch box of the stand fan
Aug 26, 2009 | Lasko 3135 Stand (Pedestal) Fan
How do you take off the spinning part off of a lasko fan?
Just hold the blade and use a sharp knife and cut the string. It's really not that hard!
Jul 28, 2009 | Lasko 3300 Wind Machine¿ Floor / Box...
Loud noises from Lasko fan motor?
The problem most likely lies within the fan motor of your Lasko unit. I just got fed up with my Lasko tower fan (model 2515) making a rumbling noise on and off and so I took apart the entire thing. I found the noise to be coming from the Decomin 2033014 motor in the unit. Took apart the motor and found that it is so cheap that it doesn't even have bearings! Just a few plastic discs on a spindle. I tried greasing the discs again but it didn't work. The only solution is to get a new motor. I am really disappointed in the quality of these Lasko fans.
Jul 07, 2009 | Lasko 2530 Elite WindTower Fan
Problem with a Lasko 3440 Floor/Box Fan.
light is on ,but there is no movement from the fan. I think I need a fan motor.Lasko 20" fan motor part #3440.
Mar 30, 2009 | Lasko 3440 Wind Tunnel Floor / Box Fan
Lasko 3723 Floor / Box Fan Logo
543 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
