Question about Delta 28-052 14'' Band Saw Blade for use with Height Attachment 105'' x 3/4'', 4 Teeth per Inch
How do you fold a bandsaw blade? - Delta 28-052 14'' Band Saw Blade for use with Height Attachment 105'' x 3/4'', 4 Teeth per Inch
  • 2,176 Answers
Gently twist it in half and then fold back against itself. USE gloves when doing this. Once you make the ftwist it will sometimes naturally fold.
Posted on May 24, 2011
The blade won't stay on even though I have it on properly it comes right off when I turn it on
I have no experience of portable bandsaws but do have some experience of workshop bandsaws.
One wheel is generally movable in order to "steer" the blade and careful adjustment is needed with the blade guides retracted until the blade runs full on the wheels. The blade guides are then brought back to prevent the pressure against the work from pushing the blade off the wheels.
Oct 04, 2015 | Milwaukee tools 6242-6 Compact PortaBand...
Bs2206 bandsaw blade
I have a 14" band saw. I also do metal cutting on my 7x12 band saw and get my blades on sawblade.com . They custom weld blade to any length.
May 10, 2014 | Saws
BANDSAW BLADES
AWSBS2 band saw takes 70 1/2" long blades. Blade Widths : 1/4", 3/8", 1/2" .
Apr 14, 2014 | Saws
How can I cut wood 3.5 inches thick with Dewalt Scroll saw?
nope... throat on scroll saw is of fixed height... beside, all scrollsaw blades are of fixed length, i would suggest use of bandsaw with very narrow blade with minimal kerf. do not use pressure on the blade! you will then have same cut through the thickness of the wood! setup bandsaw correctly, do not overtension it - see my other instructables pertaining to the bandsaw and regulation/setup of it
if you find my solution helpful - do not me shy... give some points... :-)
Jan 23, 2014 | Dewalt DW788 20" Variable-Speed Scroll Saw
! have a metal cutting bandsaw from toolmac model 73- 532501 Where can i get spare blades
One question , what happened to your blade? Why do you need spare blades? Oh ,actually,t here are lots of sites that can supply some blades for your bandsaw. Give it a try visiting sawblade.com .
Nov 04, 2012 | Saws
Replacement parts for central machinery bandsaw, blade and belt
take a look on amazon: Amazon com bandsaw blade, Last time I bought same parts from there. cheers
Dec 31, 2011 | Saws
Need a manual for a sears/craftsman model #103.24300 bandsaw
Any particular reason? If general settings problem, please follow this advice:
Brand of bandsaw is of no importance, problem is... I assume that problem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is housed driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you have problem with your bandsaw, not related to adjustments, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 15, 2010 | Craftsman Saws
Delta 28-052 14'' Band Saw Blade for use with Height Attachment 105'' x 3/4'', 4 Teeth per Inch Logo
82 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
