Question about Bunn Pour-O-Matic VPR
Can the water temprature be turned up so tht when it pours, it reads 200 degrees?
    President:
  • 1,618 Answers
Yes you will have to remove the front panel to access the thermostat and turn it up all the way then back it off a little.
Posted on May 24, 2011
Reading of 200 degrees F when immersed in boiling water. IF I cover the boiling water then it goes to 210 or so but that is a problem as when making candy I do not have a lid on the pot. Can you help?
In vigorously boiling water, it should read 212 (at sea level) or a little less, depending on your elevation - lid on or not. Maybe the water wasn't boiling fast when you got the 200 reading. Make sure the probe tip is not touching the pot sides or bottom.
Dec 16, 2017 | Taylor Measuring Tools & Sensors
How water temprature not going above 55.
Unknown what product you have.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Add a comment and describe product in detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 07, 2013 | Water Heaters
Display reading 109 degrees pool at 77 degrees so heater wont turn on
If the display is displaying what the heater thinks the water temperature is then there is likely a problem in the water temperature sensor or the board that reads it. I would be prepared to take the heater apart to measure values with a volt/ohm meter before calling the Sta Rite technical support number at 888-782-7483. They should be able to help you figure out what part is malfunctioning.
Please let me know how this turns out. Thank you.
Aug 30, 2011 | Sta Rite 200 Btu Propane Gas Heater...
What is hte proper temp on a 2008 cobalt?
Ususally the thermostat opens at 195 to 200 degrees. Coolant and pressure allow normal temps to go to 230 to 240, and much higher under heat soak condition (unit turned off). Fans kick in near that temp. So, the engine needs to be that hot to be efficient and to have emission controls shift to normal... Also the high temprature prolongs engine life by forcing moisture from the oil.
Sep 26, 2010 | 2008 Chevrolet Cobalt
Water Temprature read 126 on heater and will not fire. Pool temp @ 72 degrees. Heater set for spa @ 101 degrees. SR400NA Sta-Rite Heater
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Oct 04, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Water filter froze solid
Your refrigerator compartment temprature is below 32 degrees and freezing your water in the filter. Adjust the thermostat setting to a higher temprature setting using a thermometer in the referigerator as a refrence. 34-37 degrees is a good temprature range to keep food fresh.
Jul 31, 2009 | Refrigerators
Starbucks Aroma Grande DEAD - 200 degree overtemp electric limite
I have the same unit, but broke the lid to the caraf, so I'm elling my unit. Everything electrical works ... interested?
liquidboots@yahoo.com
Apr 10, 2009 | Starbucks Barista Quattro Coffee Maker
1991 Jeep cherokee overheating
my 91 did the same thing an all i did was pull the thermostat out.it now runs at 210 degrees and i live in phoenix,az.115 degrees outside.
Jul 22, 2008 | 1991 Jeep Cherokee Limited
Bunn Pour-O-Matic  VPR Logo
90 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
