Question about BroilKing Signet 20 Gas Grill
Just got the bbq yesterday - the 2 burners on the left ignite and burn normally. The third burner on the right won't ignite either manually or with igniter...you can hardly hear the gas coming out.
  • mrepuski May 24, 2011
    Yes! the third burner had some debris blocking - cleaned it out with wire, and works perfectly!
    Brigadier General:
  • 4,736 Answers
It may be a case, that the burner orifice for that burner is clogged with shipping debris or something similar. Remove the third burner and inspect the orifice for foreign debris. Also, check the venturi valve on the end of the burner for clogs. Onward Manufacturing, the company that makes Broil King grills is a good company and stands by their product. If you continue to have a problem with the grill contact their Customer Support Hot-line 800-265-2150.
Hope this helps you to troubleshoot and solve the problem. Please let me know and Happy Grilling
Posted on May 23, 2011
  • Rich Landrum May 24, 2011
    Glad I could help you. Now, you can enjoy your grill. Please don't forget to rate my help to you. Thanks, I will appreciate it.
Why wont the left and right burners lite using the electric ignitor?
Are the igniters for those burners sparking?
Aug 29, 2014 | Grilling
I have 3 burners...two will light and one won't light anymore.....??? Bill
Bill, I suspect that the third burner needs to be removed and thoroughly cleaned. As does the venturi valve on the open end of the burner. If however, the 3rd burner is the one that ignites from the cross over tube burner, you will have to clean and/or replace the cross over tube burner.
To assist you further, I have included a link to the Owner's Manual for your model grill, Just in case you have misplaced yours. You can download and print it for future reference.
http://help.weber.com/manuals/pdf_files_2011/Gas/Spirit%20ES%20Series%202007newer/OwnersGuides/Spirit_210310_LP_OwnersGuide_89525_030308.pdf
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks & Happy Grilling!!
Jun 17, 2011 | Weber E-210 Grill
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
Rotisserie burner won't light
It could be a dirty or inop spark electrode. Also could be weak batteries in the spark igniter.
Before you start you should make sure that the ignition system has fresh batteries. The batteries are usually located within the igniter button but not always. Some BBQs will have a battery pack located somewhere on the BBQ and others you can remove the igniter button by turning it left to reveal the battery.
First verify that the rotisserie burner can be lit manually. Take a BBQ lighter or long stick match and then put the flame right at the base of the burner where the electrode is and then slowly turn on the burner valve. It should light within four seconds. If it does not then shut the burner off and check for any restrictions in the gas line for the burner.
If it does light with a match then the spark electrode could be dirty, out of position or simply the wire for the ignition system is loose. Press the igniter button and watch the electrode for a good bright spark at the burner. If you do not see any spark you can verify that the igniter wire has not come loose and also gently adjust the position of the electrode end a little bit closer to the burner using a pair of needle nose pliers(It should not be touching the burner). It does not need to touch the burner but have a really small gap.You can use a small wire brush to gently clean the electrode of any debris that might be causing a weak or no spark
If you are unable to remedy the non-spark issue all is not lost. You can still use the manual lighting procedure I described to light the burner. And remember to be careful when trying these procedures. I do not want you to get injured from delayed gas ignition. Be careful and have a safe holiday.
Jul 04, 2010 | Ducane 30400042 (LP)
My turbo built in bbq has 4 burners. what do the
the burners need cleaning remove burners put them clr or clean out burner holes with a paper clip screws are air gas mixture best left as they are
Jun 21, 2010 | Barbeques Galore Turbo STS 4-Burner...
Weber Silver BBQ has 3 burners only 1 has normal flame.
you may have to remove the burners and clean the inside of them. they could have insect webs inside preventing the flow of gas. hope this helps. also, try opening the tank really slowly.
Oct 12, 2009 | Weber Grilling
Right front burner won't burn. Oven will not ignite.
Try lighting it with a bbq lighter. If no gas, then replace the valve. If it lights, replace the igniter. Hope this helps!
Dec 31, 2008 | Kitchen Ranges
BroilKing Signet 20 Gas Grill Logo
398 people viewed this question
Top BroilKing Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a BroilKing Grilling Expert? Answer questions, earn points and help others
