Question about Vacuums
Who makes the genesis system 4 water sofener looking for a manuel and cant find anything on the web about it
Dirt devil spot cleaner no water will come out
check to see if the water outlets are plugged with calcium or just plain dirt .knowing tho that any thing bought from goodwill is as is and buyer beware .
Jan 26, 2017 | Dirt Devil Vacuums
My genesis jet steam cleaner trips the electricity when ever I try to use it...
open it, one of the pipes can leak water and make a short. Mine did...
Jan 20, 2011 | Vacuums
How to change my vacuums belt
If you can't stretch it for enough get a bigger one and cut the bigger belt to where you want it.
May 19, 2010 | Bissell 6594 PowerForce Bagless Upright...
We don't have the owners manuel, how do you put the soap in
The top cap is the measuring cup. Look for lines at 3 or 5 ounces of soap. Fill the top container with water. If you cannot locate the exact F5914-900, any model series fo the F5900 will work, that can be downl;oaded for free at the Hoover Web site.
May 01, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Filter issue
look in the instruction manuel
May 03, 2009 | Dirt Devil Kone Vacuum- Blue Vacuum
Where do I put the water.
1. Release the handle and lay the machine
handle back to access the tank.
2. Remove the tank from the base of the
machine by lifting the tank carry handle.
3. Carry like a bucket to the sink. Rotate the handle forward
to unlatch the lid. Lift off and set the lid aside.
4. Fill up the bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the bladder.
5. Replace the top of the tank by matching the
lid and tank edges. Handle must be in the
forward position in order to replace lid. Rotate
Note: Remember to secure the lid and test to make
sure it is secure before picking up the Tank.
6. Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
You can download the manual from the Bissell website www.bissell.com
Jan 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
Amounts of Solutions
From the manual:
1. Remove the Clean/Solution Tank by lifting it
straight up, then away from the Lower Body.
2. Unscrew the black cap at the bottom of the
Clean/Solution Tank.
3. Add one of the BISSELL Advanced Cleaning formulas
for Deep Cleaning machines to the formula fill
line on the Clean/Solution tank. Fill the rest of the
tank with hot (not boiling) tap water to the water
fill line. Replace and tighten the black cap.
4. Place Clean/Solution Tank on Lower Body.
The manual is available at retrevo.com, but you have to register to get it. It doesn't open up so that I can link you to it. It doesn't cost anything though.
Hope this helps!
Dec 08, 2008 | Bissell 1770 QuickSteamer Upright Vacuum
Hoover steam carpet cleaner
does the trigger feel like it is doing anything? if not you may find that your handle lever guard is broke and needs to be replaced. this is the plastic piece at the top of your handle and can be removed by taking out the screw. if this isnt it let me know.
Sep 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
