Question about Kenmore 62602 Electric Dryer
I have a estste dryer. When i open, i see heat comes from two side. when i open, one side i see is red and another side is not. what could go wrong. How to fix. Thanks Shanti
  • 731 Answers
Heat only comes from 1 side usually the left the opening you see on the right is where the heated air goes out of the machine
Posted on May 23, 2011
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
Wirlpool Estate Gas Dryer that does not dry
i think your temperature sensor is defective in the dryer section..
check it out
May 04, 2008 | Dryers
I am trying to take the back off of my Whirlpool clothes dryer model LEQ8611LW1 to replace the heating element, but the back will not come off. How do I get to the heating element?
The dryer doesn't have a removable rear access panel and the heating element is accessible through the bottom front panel. Using a flat-blade screwdriver, locate and release the two bottom front panel clips approximately 4 inches from the sides.
Once the panel is off, locate the heating element housing is on the right side and remove the hex-head screw from the heater shield.
Remove the hex-head screw from the side of the heater housing and slide the heating element out then slide the new heating element in and secure it with the hex-head screw.
Note:
The heating element is not necessarily busted and needs to be replaced when the dryer fails to heat up. The first thing to look at is the thermal cut-off. It blows open and cut power to the heating element if the high-limit thermostat is faulty. Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
Apr 01, 2011 | Whirlpool Dryers
No heat coming out. Think it the heating element.
You should use a meter to verify if that heater is bad before getting one.
Those safetys on the side of the heater could be open and that would cause none heating.themobilian_1097.jpg
Unplug the dryer and remove the rear dust cover. After determining
I have a service manual, videos, and more HERE
Jan 27, 2011 | Kenmore 97572 Dryer
My dryer quit heating up....the one part is red and heating up but there seems to be no gas coming out and then the electric element goes out. the gas is hooked up. any solutions???
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
There is a burning smell coming from the dryer and when I open it I notice that the heating element is bright red.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 06, 2010 | Dryers
Our drying is not heating up and its not drying the clothes whats wrong with it and how do i fix it?
our drying is not heating up and its not drying the clothes whats wrong with it and how do i fix it?
Dec 30, 2009 | Kenmore 62602 Electric Dryer
Heating element
You can get to it threwthe back panel with a 1/4 in socket driver.Take the panel off and you can see the element,not hard to replace.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 15, 2009 | Kenmore 63942 Dryer
Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Feb 20, 2008 | Dryers
Dryer is not heating up
Frist need to check red and black for 220 at dryer cord the attached to dryer and see if you get 220 the way you discribed it can still be gettiong only 110 .. will bleed back from other side and give false reading.
check the hi limit themofuse on buner.. towards top on burner for continuity... check the burner thermostate, cycleing theomstate on outlet vent.. post if need more help
Nov 06, 2007 | Roper REK2950W Electric Dryer
Kenmore 62602 Electric Dryer Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
