Question about Kenmore Heating & Cooling
Kemore 580.76081500 making noise how to fix - Kenmore Heating & Cooling
My Kemore Elite 27032 sounds like an airplane taking off when it gets to the spin cycle (usually around 8 minutes remaining). What could be causing the loud noice since this is suppose to be the...
Usually, if it makes noise while it is spinning, it is the basket drive. It is probably broke. If you have a question, just write me back. Thanks.
Mar 01, 2011 | Washing Machines
Washing machine will not spin, strange noise
make and model needed,but kemore units could be the belt, coupler ,transmission. let me know if this helps.
Feb 25, 2010 | Dishwashers
Kemore 70 series make a load Squeaking noise when on spin.
I would guess it is a belt issue. You may have a worn drive belt that is making all the noise.
Dec 16, 2009 | Kenmore 24712 Top Load Washer
Kemore 80 washer will not do anything
First make sure that your outlet is getting power to your machine.  Can you hear any noise at all?  Try advancing to spin cycle and see if it will spin.  If it spins, it could be a water valve not opening to fill the machine.  If not it is probably the timer.
Oct 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kemore 110.26912690 will agitate won't spin, makes noise
You need to replace the coupling that goes between the motor and transmission
Jul 14, 2009 | Kenmore 22422 Top Load Washer
My kemore side by side is luke warm as of this morning.
Sears gives their models different numbers for example 198.215478
Look for the number so I will be on the correct model and help you better.
55c7687.jpg Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Kemore Refrigerator MODEL# 2535808789A is not cooling.
Thank You for having your model number ready, Could you remove the grate on front and bottom of refrigerator to expose the defrost timer. In the opening on front turn the timer slowly turn clockwise until you hear a click or change in operation of refrigerator. Let me know, Sea Breeze
Mar 21, 2009 | Kenmore Refrigerators
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
HE 3t Front Load Washer
Yes, there is a manual release for the door. Follow this link for step-by step instructions:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Let me know if you need further assistance. I hope this is helpful to you.
May 28, 2008 | Washing Machines
Kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Mike
Apr 10, 2008 | Refrigerators
Heating & Cooling Logo
82 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
