Question about Asko D3531XLHDSS Stainless Steel Built-in Dishwasher
SOURCE: Asko Dishwasher Model D1716B Does not fill
Have an Asko 1325 that experienced similar scenario. Removed the unit from the kitchen to the outside to do a thorough exploration. After all a dead machine is a good one to learn on. With the unit electrically disconnected, I explored within the lower guts of the machine. Found some foreign plastic debris within the turbine. Then wigled and removed each electrical connector and reconnected back. There may be corrosion within the contacts. After this procedure I test ran the machine on the outside and it worked.
BTW a common defect with the Asko is the electrical wiring leading up the main door panel, from below the machine. The wires are typically too short and the metal edges of the unit are razor sharp. You guessed it, wires become cut and cause an electrical short at best, or a fire at worst. See the photo for proof by practice. This is why an Asko can be a fiasco.
Posted on Sep 01, 2009
SOURCE: Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
Posted on May 13, 2009
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
SOURCE: Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
Posted on May 13, 2010
May 13, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Dec 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Sep 25, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Sep 10, 2009 | Asko Dishwashers
Jun 21, 2009 | Asko 1385 Dishwasher
Sep 11, 2008 | Asko W640
Jan 19, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Nov 23, 2007 | Asko D1776 Stainless Steel Built-in...
Feb 16, 2007 | Asko 24 in. D3120 Dishwasher
775 people viewed this question
