Question about Keurig B60 Coffee Maker
WHEN BREWING COFFEE WATER IS GOING BACK INTO TANK FROM THE VENT
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
My keurig keeps spitting the water back into the water reservoir and not brewing a full cup. I have cleaned the needles and have not descaled. How do I fix it??
Hi, Place your finger over the tube going back to the tank and force the water through the needle...
heatman101
Sep 11, 2011 | Keurig B60 Coffee Maker
Water heats goes back int fill tank instead of the coffee cup
heatman101
Jul 15, 2011 | Keurig B60 Coffee Maker
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Keurig B60 is real slow , displays brewing for 30 sec.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in the brewing holes and must be cleaned every once in a while. Refer to the owners manual on cleaning the coffee maker.
Jun 20, 2010 | Keurig B60 Coffee Maker
My francis francis x1 has started running very slowly, it takes about 2x longer for the shot to finish coming out than it used to.
Hi
You might need a new pump or relief valve on the pressure end of the pump. There is a hose the goes back to the water tank in the back from the relief valve. See if water is going back into the tank when you are brewing?
Dec 31, 2009 | FrancisFrancis! X1 - Stainless Steel...
Not brewing full pots of coffee
Check the in line water fliter. It may need to be changed.
You can try this also.
Put the brew basket in place with no coffee in it, put an empty decanter under the basket. take a full decanter and pour it in the water fill screen at the top of the unit. When the wtaer stops dripping and the unit is back up to temp, try a full brew cycle.
If it works OK, it just got low on water in the tank
Could be caused by a plugged up filter or lime scale build up.
Dec 28, 2009 | Bloomfield 8572 Coffee Maker
Water Feed back into the water tank.
Doesn't sound like the pump is failing. If the pump was going out, I wouldn't expect to see any water flow. There is a pressure relief value that opens if the line out the to K-Cup is obstructed.
Based on the unit I am working with, it appears the valve int he needle assembly gets clogged. I am going to take it apart to see what the root cause is.
Nov 08, 2009 | Keurig B70 Coffee Maker
I have a Bunn model VPR, I can fill it up with water, plug it in, no water. turn it on, no water. it gets hot. I opened it up, there is no restriction. What coulf cause this?
This is a pour over unit.
You fill the tank with water, it heats the water in the tank.
When the water in the tank is at brewing temp, the lite should go out.
To brew coffee with this system, you put a filter in the brew funnel, put coffee in the filter. Place the brew funnel in the slide tabs to hold in place. put an empty decanter on the warming plate under the brew funnel. Then take one decanter of fresh water and pour it in the top of the brewer where it says "WATER ONLY" the coffee will begin brewing immediatly.
Oct 26, 2009 | Bunn VPR-Black (33200.0002) Coffee Maker
Keurig B60 Coffee Maker Logo
159 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
