Question about Ingersoll Rand TS4N5 Ir Electric Stationary Air Compressor 5HP. 80 Gallon Vertical Two Stage
What weight of lubrication do i use for this compressor...Ingersoll Rand TS4N5? And do I need to bleed the tank off before adding oil?
    Novelist:
  • 205 Answers
Yes it is always a good practice to bleed the tank down. there is a check valve in the top of the receiver tank that keeps air from blowing back Thur the system. However if it's leaking you will have pressure on the oil sump. As for type of oil use a 30 weight non detergent oil. Recommend using ir's t30 all season or another type made for air compressor's.
Posted on May 28, 2011
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
Pressure asdjustment
open pressure switch an dunscrew main screw/nut inside tthis will reduce the tension on the spring inside and will cause it to cut out earlier
May 06, 2013 | Ingersoll Rand TS4N5 Ir Electric...
INGERSOLL RAND SS3P OVERHEATING OF CYLINDERS
Heat in that location noted is to be expected, but to the degree that it is should be of some concern.
When was the oil changed in the compressor last?
If you are running with a multiviscosity oil, use it only if the manual indicates it. Running straight weight oils, especially in extreme conditions is prudent insurance against failure. If you are running 10W20 for example- run 20 weight instead until regular air temps are below freezing- then the switching to 10 weightshould be a consideration..
The oil sump serves 2 purposes- 1- Coolant. 2-lubrication.
However I think the bearings in in the compressor are needing attention.
More because it sounds like there is an oiling problem in the compressor itself. At an absolute minimum it sounds like the head should be pulled to inspect for galling in the cylinder walls and to look for trace oil on the cylinder wall.
Feb 14, 2012 | Ingersoll Air Tools & Compressors
Blowing fluid out hose
The only way trans oil can get from your trans to your hose/tools is if you have bad piston(s), rings and/or cylinder(s). You'll have to removed and inspect the condition of the piston(s), rings or cylinder(s) and replace what's damaged.
Jan 29, 2012 | Ingersoll Rand Air Tools & Compressors
What size breaker do I need for a Ingersoll Rand Model TS4N5
Look at the motor tag. It should give you the run amps which I believe is about 22. What ever your amps are on the tag multiply by 1.5. If it comes up like my example (11 + 22 = 33) go to the next available size. Like 35 or 40. This should size the breaker to get the unit through start up.
Aug 07, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Oil in my air line
Oil in the air lines indicates you have air pump problems; either worn or broken piston rings or badly scored cylinder wall(s), usually both. You'll have to disassemble the air pump or take it to a service center to find out what's wrong inside pump.
Feb 01, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Can't get it to come on when it's cold.
Warm it up with a heat lamp, hair dryer etc. Release all air pressure from the tank first. Check your oil and use only compressor oil.
Dec 22, 2010 | Ingersoll Rand TS4N5 Ir Electric...
Excessive oil in the air tank and air filter housing (more than a pint). I would like to know which component is not working. it is a 2 year old UP6-10
it might be a cracked piston ring that is causing your problem, or the wrong viscosity oil. I would change the oil first using the right weight and check again. Another issue might be a stuck or sticking valve. Let me know if you need more assistance
Dec 22, 2009 | Ingersoll Rand Ingersoll-rand Up6-10-150...
Need to know what compressor oil to use for 185 ingersoll rand compressor
The parts store,napa sells a air compressor oil that is compatible,It is called simply,air compressor oil.It is made just for compressors.
Oct 06, 2009 | Air Tools & Compressors
Ingersoll Rand  TS4N5 Ir Electric Stationary Air Compressor 5HP. 80 Gallon Vertical Two Stage  Logo
301 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
