Question about Vidikron Office Equipment & Supplies
Vidikron vision 40 2003 Power will not come on now and no power light. Occassionally will come on after 10 minutes after turning on but then shut down
    Master:
  • 373 Answers
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video For similar problem on Runco projector. Very easy fix.
Posted on Nov 25, 2014
  • 236 Answers
SOURCE: Unit shuts itself down
Sounds like you have an overheating problem. Maybe a bad fan? Also you may have a bad connection to the "bulb".
Stargazer
Posted on Mar 16, 2008
SOURCE: Warning light stays solid on
The same problem as mine, is there a Canon technical support to help us fix this problem.
Posted on Aug 05, 2008
joeshea123
  • 65 Answers
SOURCE: The projector suddenly shuts off.
have you check the filter?
Posted on Mar 27, 2009
  • 69 Answers
SOURCE: Works good for 2 minutes, Then shuts down &
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Posted on Sep 21, 2009
projdoc
  • 2237 Answers
SOURCE: Optoma DV-10 shuts down completely a couple
the internal power supply needs to be replaced. after so long, the caps dry up.
Posted on Nov 16, 2009
Testimonial: "Thanks for the good info."
Vidikron 30 projector will not turn on. Power light is lit.The remote flashes red when on button is pushed but projector does not turn on
According to the user manual it must be returned to the manufacture for repair
you can contact them
Vidikron
2900 Faber Street
Union City, CA 94587
510-324-5900
Fax 510-324-5905
1-888-4-VIDIKRON
www.vidikron.com
Jul 14, 2015 | Vidikron Office Equipment & Supplies
WHY IS DRYER TURNING OFF AND 4 LIGHTS ON PANEL FLASH
Good Morning Friend,
I understand your Frigidaire dryer, model# FEQ1442ES, runs for about 10 minutes then turns off. I also see, that when it turns off, all the lights on the front panel are flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Frigidaire FEQ1442ES Electric Dryer
Honeywell CT3400. New batteries but touch pad has become unresponsive
Turn the furnace power off for 10 minutes (the control wiring up to your thermostat is powered from a transformer in the furnace) & turn it back on. Make sure you have 24 volts to the Red wire on the thermostat.
Nov 21, 2013 | Honeywell Programmable Thermostat Heater
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Belkin n1 vision turns on starts loading then shuts off
Hi Friend,
This may the issue because of the below,
Cause 1: Try to insert the Power plug adapter in any other wall outlet
Cause 2: Check by Resetting the Router,(Insert a Pen or Paper Clip inside the Reset hole and hold the button until the lights are getting turn off,once its goes off without taking the hand from the reset unplug the power cable from the router and plug it again after 10 sec,Now take the pen or paper clip from the reset hole)
Cause 3: Even now you are not having any solution,then the router is gone bad,you may go for a replacement
If any other clarification,please feel free to contact us
Regards,
Ayyasam
Mar 31, 2010 | Belkin N1 Vision Router
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Vizio 47' lcd
    PROFESSIONAL REPAIRER OF:
    * cd-vcd-dvd-ld player.
    * colour tv, Lcd/plasma tv.
    * projection tv.
    * prologic AMPS
    * Grill/microwave oven's
    * Digital proffesional camera.
    * Digital camcorders.
    * LCD/Digital projector.
    * Hi-Fi music system.
    * FAX machine.
    * printer/scanner/copier.
    * play station (PS1-PS2).
    * X-BOX360.
    DIAL..........: 9820380682
    Jan 23, 2008 | Vizio VX32L Television
    110 people viewed this question
    Top Vidikron Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Vidikron Office Equipment and Supply Expert? Answer questions, earn points and help others
