Question about GE DVL223EBWW Electric Dryer
How do you get top or front of cabinet off? - GE DVL223EBWW Electric Dryer
    Master:
    Sergeant:
  • 385 Answers
There are small clips between the top and the front cabinet. You need to use a bright light to find them, then use something like a small putty knife to go in between and release them. After that you will see how to take off the front. Hope this helps.
Posted on May 23, 2011
The belt attached to the blower wheel on my Whirlpool Cabrio dryer has come off. How do I reattach it?
Unplug the power cord of the Whirlpool dryer from the electrical outlet before installing a new belt. Remove the lint filter from underneath the lint filter cover. 2 Unfasten the screws underneath the lint filter cover with a screwdriver, setting the screws in a safe place. Slide a putty knife between the dryer top and the cabinet near the front, lifting up on the knife to detach the top from the plastic clips on the cabinet.3 Flip the dryer top back against the wall so it is resting on the rear hinges. Locate the screws on the inside of the upper front panel near the top.4 Unfasten the screws on the inside of the upper front panel with a screwdriver. Lift the panel up off the metal clips on the front of the dryer cabinet. 5 Unplug the door switch connector from the back of the upper front panel by hand, setting the panel out of the way. Slide the putty knife between the lower front panel and the dryer cabinet, pulling the knife away from the cabinet to detach the panel from the plastic clips on the cabinet.6 Place a couple of wood blocks under the lip of the dryer drum to hold it in place. Locate the idler arm near the motor at the base of the dryer.7 Move the idler arm forward to relieve the tension on the belt. Take the belt off the motor and idler arm pulleys, lifting the drum up and sliding the belt off the drum.8 Install a new belt around the dryer drum, looping it over the idler arm and around the motor pulley. Move the idler arm back into position to add tension to the new belt.9 Remove the wood blocks from underneath the lip of the dryer drum. Plug the door switch connector into the back of the upper front panel by hand.10 Slide the upper front panel over the metal clips on the front of the dryer cabinet, securing the top of the panel with screws. Fasten the lower front panel to the front of the dryer cabinet, pressing the panel onto the plastic clips by hand.11 Flip the dryer top back down onto the top of the cabinet, pressing down to secure the top to the plastic clips on the cabinet. Fasten the screws underneath the lint filter cover with a screwdriver.12 Slide the lint filter back under the lint filter cover by hand. Plug the power cord of the Whirlpool dryer into the electrical outlet.
  • Oct 11, 2011 | Whirlpool Dryers
    On Maytag dryer model # MDE9316AYA how do I get the top off? One of the fins inside the drum is loose, and I hope I can reach the screws to tighten it up by removing the top, but it won't budge and...
    Opening the cabinet of these machines begins with the cabinet top. There are two spring catches located just below the cabinet top that secure it to the rest of the unit. These catches are located towards each side edge. Use a putty knife (or some other thin and flat object) to slide in under the cabinet top to disengage each of the clips. You can now lift up the cabinet top.
    With the cabinet top lifted, you will see two screws located inside the top of the cabinet front. Remove each of these screws and lift the front panel to disengage the two clips found at the bottom. As you remove the front panel, disconnect the door switch and any other wiring, taking careful note of which wires are to be reconnected where.
    Jun 13, 2011 | Maytag Dryers
    I don't have a repair manual for White Westinghouse dryer. Need to replace heating element. Not sure how to get to the element
    Instructions
      • Disconnect the power cord from the electrical outlet before servicing the Westinghouse dryer.
      • Insert the putty knife into the gap above the front panel and below the top panel. Lift the putty knife handle up to unfasten the internal locking clips.
      • Lift the top panel from the dryer cabinet. Rest the panel on the wall behind the dryer.
      • Remove the two screws on the top border of the front panel. Lift the front panel straight up to unhook it from the dryer cabinet. Unplug the connector leading into the front panel. Set the front panel aside.
      • Move the idler pulley arm toward the front of the dryer cabinet to loosen the belt. Remove the belt from the drum and pulleys.
      • Lift the drum out of the dryer cabinet.
      • Disconnect the electrical plugs leading into the heating element. Unfasten the screws securing the element to the inside of the cabinet. Lift the element out of the cabinet.
      • Place the new heating element inside the dryer. Connect the screws holding the element to the cabinet. Plug the electrical connectors into the element.
      • Reposition the front panel. Plug the door switch connector into its socket on the front panel. Press the panel straight down into the base. Reinstall the screws along the top of the panel.
      • Lower the top panel onto the dryer. Press down on the panel to lock it into place
    May 12, 2011 | Dryers
    How to fit a belt to a hotpoint v3d01 dryer
    Instructions
    Tools Needed:
    Screwdriver
    Hand vacuum
    1. Unplug the electrical cord of the Hotpoint tumble dryer from the electrical outlet before attempting to replace the belt.
    2. Pull the door open on the dryer and locate the screws on the underside of the top cover. Unfastening the screws with a screwdriver.
    3. Flip the top cover back so that it rests on the rear hinges, and find the screws on the top of the front panel on the inside of the dryer cabinet.
    4. Undo the screws on the top of the front panel with a screwdriver, and tilt the panel away from the dryer cabinet. Unplug the door switch connector from the metal prongs on the back of the front panel.
    5. Lift the front panel up and remove it from the dryer cabinet. Set it out of the way. Locate the idler arm and motor on the bottom of the cabinet.
    6. Move the idler arm forward to relieve the tension on the belt, and take the belt off the idler arm and motor pulley as well as from around the drum.
    7. Place the new belt around the drum, looping it over the idler arm pulley and around the motor pulley. Move the idler arm back into place to add tension to the belt.
    8. Verify that the belt is lined up correctly with no twists in it, and put the front panel back on the dryer cabinet. Plug the door switch connector into the metal prong on the back of the panel by hand.
    9. Secure the front panel with the screws at the top, and flip the top cover down over the cabinet. Secure the top with the screws on the underside of the front lip.
    Feb 23, 2011 | Dryers
    How do I remove the top of the washer to replace the lid switch on a 110 23832100?
    Disconnect power then release the console from the top of the cabinet. Pull or pry off the end caps then remove the screw that secures the console to the cabinet top. Once the screws are removed, pull forward and up on the console and lay it back on the hinges.
    Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
    The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
    Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
    Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
    Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
    Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
    Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
    major_appliances;subcat=washing_machines;brand=kenmore;product=kenmore_22422_top_load_washer;ptype=thread;make=kenmore;solution=1;channel=0197193999;sz=650x250%2c2x2;tile=3;ord=634994898287111? Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
    Dec 30, 2010 | Kenmore Washing Machines
    How can I replace the pump belt of a washing machine Sears Kenmore model #110.82671710 stock #26717
    The Kenmore top load washing with the given model number 110.82671710 is a direct-drive type and doesn't have a pump belt. The pump is directly coupled to the rear spline of the motor.
    The cabinet needs to be removed if access to the drain pump and replacement is necessary. Remove the screws attaching the bottom front corner of the console to the top of the cabinet then pull forward and up on the console and lay it back on the hinges.
    Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base. Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up and set the cabinet aside.
    With the cabinet removed, pry the clips securing the pump to the motor off and remove the pump.
    Detach the hoses from the drain pump and attach it to the new one then install it back into the rear spline of the motor and secure it with the retaining clips. Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
    Dec 23, 2010 | Kenmore Washing Machines
    The washer filled up with water but wont turn on
    This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch. The machine, therefore, will not turn on when the lid switch is not working. Manually activate the lid switch and if still doesn't work, bypass the lid switch. Disconnect power then jump a wire between the outer terminals of the disconnected connector from the cabinet top then reconnect power. Replace the lid switch to address the problem if the machine works with the lid switch bypassed.
    Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
    Nov 09, 2010 | Whirlpool LSN1000LW Top Load Washer
    Kenmore model 110 top load washer water drips out slowly, takes a long time to fill tank
    Either the inlet hose screens or the water inlet valve screens or the the water inlet valves not opening completely. Check the screens and the water flow from the inlet hoses by removing them from the water inlet valves. The water valves are not opening properly and needs replacing if the screens are clear and the water flow from the inlet hoses are good.
    Remove the cabinet to access and replace the water inlet valve assembly. Unplug the machine from the electrical supply then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
    Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and set it aside. You can now remove the water inlet valve assembly and install the new one then reassembly the machine.
    Sep 25, 2010 | Kenmore 15864/15862 Top Load Washer
    I can't get the top off my Maytag performa MD2300 dryer. I used the putty knife idea but the clip won't budge. I'm pushing straight in from the front, cheating a little up, then down. It's like hitting a...
    The top cover is held by two hold down brackets hidden behind the front panel posts. Lifting of the top cover requires the removal of the front panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
    Open the dryer door and remove the four screws located vertically along the inside lip of the door opening and securing the front panel to the front shroud assembly.
    The front panel is held to the cabinet by clips on each side secured to the cabinet front flange. Small slots in each side of the front panel engage the clips and hold the front panel in place. Grasp the sides of the front panel near the top cover then pull the front panel away from the cabinet.
    Tilt the top of the front panel away from the cabinet and lift it up to release it from the two clips retaining its bottom to the base of the dryer, and then move the panel away.
    Locate and remove the 5/16" hex-head screw attaching each hold down bracket to the cabinet. Swing each bracket to the outside then unhook it from the slot in the lip of the top cover. Lift the front of the top cover and flip it to the rear of the dryer.
    Reassemble the front panel and the top cover by reversing the given disassembly steps.
    Mar 25, 2010 | Dryers
    Need to Know how to remove top and cabinet
    first, do you have phillips screws on back of console at bottom goin down or in front bottom? one or the other remove these then slide console forward and fold back on hinge on top. if no screws then clips are hidden on front edge on end plates. use putty knife from front to push and release lifting console at same time. fold back.
    use screw driver to pry and release brass clips holding top to rear panel. unplug lid sw connector and pull cabinet body away from machine. top and cabinet is screwed together and removed as one piece. cabinet hinges under base on front and sits on top of sides.
    May 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    GE DVL223EBWW Electric Dryer Logo
    54 people viewed this question
    Top GE Dryers Experts
    John Tripp
    John Tripp
    Sal DeAngelo
    Are you a GE Dryer Expert? Answer questions, earn points and help others
