Question about Spirit Weslo FREE SPIRIT 815 Treadmill Walking Belt
8 seconds after starting it stops with a L5 code. Please advise what could be wrong
  • 910 Answers
The L5 problem is with the Magnetic Speed Sensor (Tachometer). It's located next to the wheel on the belt. There's a metal disc in the wheel on the belt and as it passes the sensor it registers and calculates the speed based on how often it passes. Sometimes the sensor slides too far back and therefore can`t register the magnet passing by.
You'll need to just keep trying to adjust it until you find the point at which it works correctly and then glue it in place.
Posted on May 23, 2011
HI our Bowflex series 3 treadmill is giving us a continued Err L5 code when trying to use our machine. We bought it used so do NOT have ant trouble shooting instructions. Any advice?
Hi There, L5 error should refer to the "LS" error which looks up to a speed problem. When you start the machine up, it boots fine and then when you press start or go is says err ls ? If the walking belt doesn't move at all when you try to start it, listen for a "Click" on that lower board when start is pressed..... If the walking belt moves for a second and then stops and the console says err ls, then you may have a speed sensor problem. These control boards are repaired by Jatinah Electronics who can be found with a google search. Good Luck!
Dec 13, 2016 | Bowflex Exercise & Fitness
What is L5 mean
Hi dear.That should be LS Code instead of L5.Please check the followings.I hope that helps.Thanks.
LS
Lid Switch Error
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
Sep 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error E5 or L5???
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
What is L5 code on whirlpool calypso model #GVW9959KQ0?
Aug 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer stops working and the light flashes L5
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jun 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
L5 show in display and won't work in calypso washer
ss13679,
I believe your code is actually 'LS'. This codes shows up when the controller cannot detect the lid switch opening and closing properly. This error code may also be used if there is a diagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if you press the start key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Your lid switch may be bad. Click here for some help. Also it looks lik this: click here
Hope this helps. Please give me a vote!
-samson39
Jul 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
KENMORE CALYPSO WASHING MACHINE
Jan 26, 2009 | Washing Machines
For the kenmore elite oasis he top load washer, what does the error code DL mean and how do i fix it
We jamed a straw in the door lock so the sensor thinks there is something in there
Jul 02, 2008 | Washing Machines
Spirit Weslo FREE SPIRIT 815 Treadmill Walking Belt Logo
311 people viewed this question
Top Spirit Exercise & Fitness Experts
MrJunk
Level 1 Expert
Electro Med Services...
Tom Chichester
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
