Question about HP DeskJet 6988 Printer
I do not have a maintenance option to select on my properties for my HP Deskjet 6988 and it's in desperate need of a cleaning
  • HP Master
  • 838 Answers
There is very limited support for this model and none from HP. Windows 7 loaded a generic driver when you plugged in the usb cable. What you got is all you are going to get.
This is the pitfall of a new operating system and an older printer.
Posted on May 23, 2011
HP Deskjet 6940 InkJet Printer, white lines across
do a clean - goto printer properties - should see tools
there you can choose to do a clean or deepclean
also try a head alignment on the maintenance section
Jul 15, 2014 | HP Deskjet 6940 InkJet Printer
I am having a hp deskjet printer model d 1668 and the ink in the cartridge was exhausted before one month and i removed the cartridge./ now i bought a new cartridge but the systems shows there is a error...
A cleaning will fix the problem. To clean your Canon HP D1668 > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
Hope this help, thanks!
Oct 08, 2011 | Office Equipment & Supplies
My Hp deskjet F4235 is not printing very good. I can barely read what it prints out. My printer is telling me that the ink is full.
You may need to run the maintenance processes such as head cleaning and alignment. It should be one of the tabs under the printer properties. Right click on the printer, choose printer properties, Maintenance. It depends from printer to printer. The alignment most likely is the culprit.
Jun 30, 2011 | HP Deskjet F4235 AllInOne InkJet Printer
This printer is not working as it should; it prints blank pages instead of printing a document; reinstalled the software to no avail; i'm getting bored and angry with it; need solutions urgently; whenever...
It sounds very much like your print heads are blocked. If you have not tried already then run your maintenance program or right click on your printer item in the control panel and select the properties option. Then select maintenance.
May 29, 2010 | HP DeskJet 6988 Printer
I am getting unwanted black stripes when i do colour-printing. on my old pc i used to be able to clean/test the printing head but i dont have that facility now & can't see it on the net. any tips...
First run a cleaning cycle and test print. You can get this from Control Panel - Printers - Select Printer name and right click - select Properties and then Maintenance.
Then
1. Select Normal or Best, rather than Draft, in the Paper Type/Quality option in the Page Setup Screen.
2. Align the print cartridges. Select the Calibrate panel on the HP deskjet utility screen, then click the Align button.
3. Decrease ink density or drying time.
a. Click File > Print > Paper Type/Quality.
b. Click the Ink tab.
c. Use the sliders to adjust ink density and ink dry time.
Oct 07, 2009 | HP DeskJet 960c InkJet Printer
When I try to print in colour I get yellow lines through everything. The cartridge is new so it's not running out of ink. Do I need to clean the heads somehow? If so, how do I do this?
Find the printer in Control panel, right click, select properties, click printing properties, click maintenance, click nozzle check or head cleaning
May 24, 2009 | HP DeskJet 940c InkJet Printer
My printer has a full black in cartridge, but the print is gray and blurry
Try going into Control Panel
--> Printers and Faxes
--> Right Click on the Printer ICON and select Properties
Look for a maintenance or tools Tab across the top and try Cleaning or Deep Cleaning
Jan 25, 2009 | HP DeskJet 5740 InkJet Photo Printer
Hp deskjet 960c
You say it stopped working mid-print... possible paper jam? Ink cartridge not clicked in all the way? (they should all line up evenly across the tops).
In control panel->printers and faxes, right click on Canoni960 and choose properties. In maintenance tab try to do nozzle check and print head alignment. In lower right corner is status monitor, click to see if any useful information in there.
May 17, 2008 | HP DeskJet 960c InkJet Printer
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Apr 08, 2008 | HP DeskJet 940c InkJet Printer
HP DeskJet 6988 Printer Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
