Question about Gateway 975 Rackmount (gtwy975) Server
Cant find driver for scsi hdd to install windows server 2003
I cant intall window 2003 in IBM server x3400 , wher to find the SCSI driver < took me 24 hours and i didnt find it yet anyhelp thx.....
You can install Windows 2003 using IBM Service Guide CD. Its an image file (.iso) . Burn it after download . Then boot from cd and follow the simple wizard . Find the link below
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5088993
Thanks
Nov 15, 2011 | IBM x3400 Server
How to install scsi driver for hp prolaint ml 350 server and then install server 2003,because my os 2003 is currpted.
windows server 2003 enterprise edition with SP1 or SP2 , can detect
SCSI driver automatically.
Apr 22, 2011 | HP Compaq ProLiant ML350 G3 Server
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
How to repair server 2003 in IBM 226 server
first you need to prepare the scsi drives ie host raid adapter scsi drivers are server raid cotroller 6 scsi drivers by using the serevr raid support cd dikettitools proper os drivers to floppy and boot with widows cd at the time starting boot press f6 to specify the scsi drivers then all scsi hdd will detect for installatio.
Jan 18, 2010 | IBM xSeries 226 Server
I cannot install windows xp in ibm x3400,the system is currently raid5,it shows message hard disk not detected. thanks
I believe your HDD must be a SCSI disk whose drivers might have come along with the HDD.While installing XP it gives an option to install third party drivers for your HDD, Hopefully after that it would start detecting
Aug 26, 2009 | IBM x3400 Server
Ibm server xseries 326
It is not detecting the HDD because the windows install does not have the necessary drivers. On the windwos install you must press F6 or F2 I don't remember which one but it prompts you for them to load external drivers fro SCSI or other type of drives, you must download the right drivers for the type of HDD the server has probably fromt eh IBM support website, put them in a floppy and load them from the floppy into the windows install so it recognizes the drives..
Jun 02, 2009 | IBM eserver xSeries 360 8686
Can not install windows server 2003 on Acer Altos G710
Hi! Turn off computer check cable & power cable connection. Windows 2003 Operating System will not support SCSI Drives.
Apr 08, 2009 | Acer Altos G710 Server
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
Hdd
I prepare server 2003, cause I do not have much knowledge with linux OS (but I'm starting to learn :D).
Yes, you may need to load the drivers first if your using a new mobo. Some Mobo cannot detect a scsi hdd unless you load its drivers. (usually its F6)
Are you going to create a dual boot OS?
May 10, 2008 | Intel Server Board STL2 Motherboard
Gateway 975 Rackmount (gtwy975) Server Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
