Question about Mtd Products Yard Machines 158CC Tiller
I have a Briggs and Stratton (135202) tiller that starts but dies a few seconds later. I see an aluminum tube that goes from the carburetor to the engine. At both ends are rubber hose pieces that connect the tube to the carburetor and to the engine. Those rubber hose pieces are dry rotted. Could this be the problem. If so, where could I get new rubber hose pieces? Any help would be appreciated!
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I NEED A DIAGRAM OF A BRIGGS AND STRATTON TROY
Go to link below for a parts break down for your tiller. Starts on page 23
http://dl.owneriq.net/c/c23c1d7c-74ff-4347-b31e-a0ee0462b35e.pdf
Posted on Apr 17, 2010
  • 15273 Answers
SOURCE: Hello, I have a Briggs and Stratton (135202)
check air filter and or carb might need cleaning or adjustment
Posted on May 06, 2010
Vacuum leak
tighten up your carburetor
that will stop any air leaks
Apr 10, 2014 | BRIGGS_AND_STRATTON...
Briggs and Stratton intek 900 Series 205cc It will starts but it wont stay running.
The usual cause for the problem you describe is related to fuel/
carburetion. Today's formulation of gasolines have a shelf life of only 4-6 months before they start gumming carburetor. Other forms of fuel contamination (dirt, water, etc) may also be the culprit. First step is to remove and thoroughly clean both the tank and carburetor. Reinstall. Install a small engine filter in the gas line when you reassemble. Use FRESH gasoline after you are ready to start your engine.
Oct 14, 2013 | Briggs AND Stratton Intek Briggs &...
Dynamark 3.5 Model 20211X18A. Looking for manuel, I prime 2 times to start. Engines starts then dies. If I continue to push prime button it will keep running, barely, however, dies as soon as I stop...
Could be 2 things: a restriction in your fuel line/coming out of the tank, or 2: a dirty carburetor needing to be removed, cleaned and possibly rebuilt and reinstalled. Hope it's one of those.Start with pulling the fuel line loose from the carburetor. If you have fuel flowing freely, plug the hose with a golf tee and move onto removing the carburetor. Carb kits are cheap and easy to install. It's best to rebuild while you have it off to avoid similar problems later.
Sep 30, 2013 | Briggs & Stratton Briggs Stratton...
Where do I get a rebuild carburetor kit of a 1973 Briggs and Stratton rotor tiller?
with the model and spec numbers from the front cover any power equipment shop should have the parts
Jun 05, 2012 | Briggs & Stratton Garden
I bought this tiller off Craig's list. He was up front and told me he had use starting fluid to get it started but that it ran after that. I brought it home started it (via starting fluid) went to the...
your carburetor needs cleaning &,or otherwise before this, try removing the "sediment-bowl" located under the carburetor,needs removal and checking for water and dirt in this bowl and possibly new gasoline in the gas tank, if contaminated with water/dirt after purging all lines after this
Apr 01, 2011 | Briggs & Stratton Garden
I need a diagram for the carburetor linkage on a yard machine tiller model number 216-430 or a diagram linkage on a briggs and stratton engine model no. 135202
go to partstree.com and get a diagram for this.
hope this helps you.let me know.if you cant find it ill get you one ok.let me know
Jul 21, 2009 | Garden
Throttle linkange spring connection
goe to briggs and stratton .com and put your model type and code it will bring up your diagram and that will help.
Jun 27, 2009 | Garden
The engine doesn't start. I didn't use it for several years. It started and ran well for about an hour; when I shut it off, I could not restart. I have tried the obvious...new plug, putting started
You need to give the carburetor a good cleaning, as well as the air filter. Chances are the carb. will need a new carb. kit since it has been years since you last used it. If you need tips on how to clean the carb., just let me know.
Jim
May 30, 2009 | Mtd Garden
What year was the tiller made with model #135202 made
That model was made in the mid 1970's by several manufacturers. Most had a Briggs and Stratton Engine. You could call Briggs & Stratton Customer Support: (414) 259-5333. If anyone can get you the manual, perhaps they can.
May 06, 2009 | Garden
Mtd Products  Yard Machines  158CC Tiller Logo
66 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
