Question about Brother MFC-9440CN Laser Printer
I cannot correct the date/time on sent and recieved faxes
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 306 Answers
May be the CMOS battery was weak...
you can replace a new.
Posted on May 23, 2011
2 Suggested Answers
  • 111 Answers
SOURCE: Setting date/time stamp for faxes HPC6180
Do you still have the manual that came with the machine? It should have the original setup instructions. I looked on HP's site and couldn't find anything that specifically answered your question, but if you don't have the manual any longer, you can download a copy from HP. It should have what you need:
HP C6180 Manuals
Posted on Sep 29, 2008
How do I print the fax confirmation page on the x4270? Are the instructions printed anywhere? How to set the time?
here's the solution to enabling fax confirmation: press the fax button on the printer front panel,the press option 16 or until advanced fax appears.(you can also press the right arrow to get to that option). press select push options twice.fax confirmation menu will come on the front panel display.push the right arrow button. The following options are displayed: Off - Select this option to receive no confirmation. Print for all - Select this option to receive confirmation whenever a fax has been sent, whether successfully or not. Print for errors - Select this option to receive confirmation (an error page) only when a fax has not been sent/received successfully.
***************************** here's the solution for setting time on printer display on the printer control panel,push fax push options until EDIT DATE/TIME: appears on the printer display to change the date: - press select - use the keypad buttons to enter the date. Note: If you make an error entering the date, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction. - press select
To change the time: Press the right arrow once, and then press Select. Press 1 for 12-hour time or 2 for 24-hour time. Use the keypad buttons to enter the time you want your All-In-One to display. Note: If you make an error entering the time, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction.
Press Select. If you are using 12-hour time, press 1 for AM or 2 for PM. Note: If the time is entered incorrectly, the time shown will be the default.
************************************************** i will also put in the link for the manual for additional assistance: http://www.lexmark.com/publications/pdfs/4200/eng/frameset.html
Jun 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do you retrieve faxes you have sent?
You can't retrieve sent faxes but you can use menu and scroll down to reports and select fax activity and get a report of faxes sent with the phone numbers time and date sent.
Jan 05, 2010 | Brother MFC 420CN All-In-One InkJet...
Is there a way for me to leave a date/time stamp when sending a fax on my intellifax 1940CN?
if you enable send report you can get an a4 page with time and date confirming that the fax has been sent, but when set up it will print for every fax. the other option is to have it print on error only and you can manually print report of sent recieved items( all date and time stamped) with the number sent to as a list.
Aug 10, 2009 | Brother IntelliFAX 5750e Laser Fax
Time date stamp on fax machine
The time it was sent, if they have the time set correctly on the sending fax machine
Mar 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Wrong time printed on fax
  1. From the machine, press the [Menu] button until 'Machine Setup' appears on the top line of the display.
  2. Press the right arrow button until 'Date & Time' is displayed on the bottom line, then press [Enter].
    1. Enter the correct time and date using the numeric keypad. By default, the machine clock mode is set to 12-hour format; however, this can be changed to a 24-hour format (see the change the clock mode section below).
    2. Month = 01 ~ 12
      Day = 01 ~ 31
      Year = requires four digits
      Hour = 01 ~ 12 (12-hour mode)
      00 ~ 23 (24-hour mode)
      Minute = 00 ~ 59
    Note: To select 'AM' or 'PM' for a 12-hour format, press the * or # button or any number button.
    1. Once the correct date and time has been entered, press [Enter].
    2. Press the [Stop / Clear] button to return the machine to Standby mode
    Feb 19, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
    Printing a sent fax
    in the settings of the fax there is a setting in reports that you have to turn on conformation with print out.
    that gives you time date and 1/2 of the top page of fax sent
    May 20, 2008 | HP LaserJet 3050 All-In-One Printer
    Still can't get fax not to pick up when answering machine is connected.
    if you have the fax-575 there should be a TAD setting.
    This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
    To set the Recieve Mode :
    Press Recieve Mode. The LCD display shows your current selection.
    Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
    The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
    Hope this helps!!!
    Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
    Time
    This should take care of it for you.
    NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
    1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
    2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
    3. Press the [Start / Enter] button.
    4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
      NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
    5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
    6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
    7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
    Dec 13, 2007 | Office Equipment & Supplies
    Change Date/Time on Canon Fax L350
    Left the flap on the right hand side of the fax machine.
    Select Data registration
    use the down arrow
    1. Data registration
    SET
    1. User Settings
    SET
    1. Date & Time
    SET
    Enter date or time
    SET
    Nov 16, 2007 | Canon FAX-L350 Plain Paper Laser
    Jounal Entry Dates
    Most machines will only keep a certain amount of transactions in memory. Your fax that you are looking for is probably over the amount of transmissions kept in memory. One suggestion, if the fax was a long distance number, you could check your phone for that number. You also might want to set your machine to print a confirmation report for every fax sent and staple it to your fax for further reference.
    Jun 25, 2007 | Muratec F320 Plain Paper LED Fax
    Brother MFC-9440CN Laser Printer Logo
    52 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
