Question about HP Officejet Pro L7680 All-In-One Printer
I'm getting the error message: "save failure"
I'm getting the error message: "save failure" when trying to scan a doc. to a memory device.
  • hanthony835 May 25, 2011
    Thanks Riztech, I've tried different memory devices so that's not the issue.
    I appreciate the reply.
    Guru:
  • 731 Answers
If your card has a small switch on the side, make sure that the switch is in the unlocked position.
Regards
Riztech
Posted on May 23, 2011
    Thanks Riztech,
    I've tried different flash drives so that's not the issue.
  • Mohammed Rizwan
    Mohammed Rizwan May 25, 2011
    Okay! so it must be with the printer. Try a partial reset as below
    >>Take the memory card out and remove USB cable from printer.
    >>Remove the power cable from back side of the printer while its ON.
    >>Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
    >> If printer turns OFF, press power button to turn it ON.
    Regards
    Riztech
Dantz 6.5 error message?
it refers to the memory selected for to be the location for the final result ..or there is not enough in the C drive ..if the drive is made too small
Dec 17, 2011 | Computers & Internet
I viewed pictures on my computer and didn't upload them. When I placed my sdhc card back in my camera it gave me the error message "memory card error" and "card locked", however the...
Don't be panic. you can try some data recovery software. You can see
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html?part=dl-75328850&subj=dl&tag=button
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Jul 15, 2011 | Cameras
I am getting a "Memory
Its a very common problem with S400,S410 and some others.
As a case study, see the following error message on the Canon IXUS 130 when trying to view some photos previously stored in the memory card SDHC
"Memory Card Error"
Every single photo stored on the memory card becomes inaccessible after the above error message. In addition, no more photos can be stored on the memory card. In short, the card can not be read or written.
Cause:
The above error message that makes all the pictures inaccessible is mainly caused due to corruption of the memory card. Reasons why you are responsible for the above error message is virus infection, interrupted read / write operation, and human error.
Resolution:
The resolution for the above error message is the format of memory card into the camera. The process erases all data previously stored and allows you to save the new data. While the format is a good resolution for users who do not require the old data, it is fatal to users such as photographers, detective agencies, etc, to save critical data on your memory card. However, the formatted data recovery day is now an easy process. It is therefore necessary to use an advanced part of third parties. A tool for image recovery is readily available on the Internet by one click.
Data Recovery is an application of high-end recovery that recovers data from almost all formats SDHC Card, XD and MMC. The read-only photo recovery tool also allows you to restore data in the defined location. The software runs on Mac OS X and Windows.
Check this link for additional details: Simple Fixes for SD "Memory Card Locked" or "Memory Card Error"
Hope helps.
Jun 07, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
When I am trying to open any saved files in MSWord, I get an error message saying "Windows cannot find example/file.docx. Make sure you have typed the name correctly, and try again." Even when I...
-Run regedit (Start menu, run, etc.) and go to this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Word\Addins
-Export all the addins to a reg file (for backup)
-Then delete all of them in the registry (or one at a time if you want to
know which addin is causing the problem,
-Now try opening a .docx or .doc file in windows explorer and find that
document loads properly with out any error messages!
-now exit MS Word and open the reg file(s) you exported and import them back
-try opening a .docx file again and the problem is fixed. hope this works for you
May 05, 2011 | Computers & Internet
Impact s305 printer won't scan. it's stuck on "downloading application list"
Try using the Lexmark Printer Home when scanning. If you have a PC, to access it click on Start > All Programs > Lexmark > Printer Home. You can scan to a .jpeg, PDF or .doc.
If you're scanning from the control panel of your printer and you're getting an error message, "Cannot Retrieve Application List", most probably your firewall is blocking your printer from downloading the applications. You might want to add the Lexmark files in the exception of your firewall. Click on the link on how to add exceptions to your firewall.
If you're trying to scan to email (email client), try to check this link: http://bit.ly/k0w0Hp
Mar 11, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Ok, if try to open my Contacts I'm getting an error message saying "Not enough memory to perform operation. Delete some data first." I am getting this same error message on virtually every...
since you tried everything..let me give yu the ultimate solution
1.go to file manager and backup phone on memory card and remove it
2.go to settings<phone managment<factory settings
3.enter password and reset the phone
4.after resetting insert memory card and restore
Mar 05, 2011 | Cell Phones
When I go to scan a doc to e-mail I get an error message that says (Not Set Up on PC) and I am unable to scan and send a doc via e=mail
Well as a workaround, as long as you can actually scan and save ... What you do is scan what you want, save it, then either save it as a PDF OR convert it to PDF After which you can then "Attach" it to any email you wish. I recommend PDF as most people have Adobe Reader.
If you can't scan to PDF, and it only saves as say JPEG, then get DoPDF http://www.dopdf.com/ To convert it from JPEG, JPG, BMP etc.
Feb 03, 2010 | HP LaserJet 3050 All-In-One Printer
Problem saving scanned negatives to laptop. Epson 2400 scanner.
If you are scanning in Color and in high resolution, then the file size will be very big. Try and close other programmes in your Laptop and try. If in color try 150 or 200 dpi option and also select JPG format. Alternatively you can increase your RAM in the laptop. S. Mohan
Nov 13, 2008 | Epson Perfection 2400 Photo Flatbed...
SCANNING PROBLEM
Maybe that JPG has very high quality, big size that Word cant handle it, it sometimes happens. Try to put it on some other text-editing software, I bet that WORD doesnt handle that big JPG. Happend for me also :) try to upload it to an image-hosting site, then just put the link in the DOC :)
Mar 13, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
HP Officejet Pro L7680 All-In-One Printer Logo
178 people viewed this question
Seeker5211
Seeker5211
