Is the 42lh3000 TV compatible with the ht805sh home cinema system for getting TV sound through the speakers? i have it set up and works fine with DVD sound but i cant get the TV sound to come through it?
  • 961 Answers
I looked at your two products and I'm not quite sure how you have it hooked up but, your TV has a total of 3 HDMI inputs and, a digital optical out, which means, that all your video componenets, DVD cable/sat, if you have, should be able to be connected directly to your TV. You can use the TV's menu to chosse what you want to watch. The TV also has a digital optical out, which you would connect to the digital optical in of the home theater. You would use one setting(sat, aux, whatever, depending on theater inputs), and when have "TV" selected in your menu, you should have sound through theater. You may have to turn volume down or mute for this to work. If you have any questions, let me know.
Posted on May 23, 2011
Sound goes on and off while watching programmes every so often
This sounds like you have the device on a wrong sound setting. Check the sound settings. For example Dolby sound needs special settings.
Jan 13, 2016 | Panasonic 5.1 DVD Home Cinema System 1000W...
Cant hear my digital tv through my home cinema speakers
http://www.dummies.com/how-to/content/how-to-connect-an-hdtv-to-your-sound-system-or-home-theater.html
Matthew, I found this link which covers the basic possibilities for connections. It has a video backed up by the text version as well. Hope it helps.
Dec 07, 2013 | Samsung HT-X200 Theater System
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
How to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Just bought SAMSUNG HT X200R HTK home cinema system and I can not get the sound to work through the tv, it does however work through the DVD, can you help?
There are so many things to be consindered 1.does your tv sound comes out from the speaker without connecting the DVD
2.If the speakers from the tv ok,check the av line on the chassis of your tv set/check the av cables
Apr 22, 2008 | Televison & Video
Trying to install a new 50
a good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
hope this helps
Feb 09, 2008 | Televison & Video
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
104 people viewed this question
 Grubhead
Grubhead
