Constant beep of phoenix motherboard abit ab9-udboo1268 but it loads up and runs no problem on windows xp
  • 50 Answers
Have you checked the motherboard battery?
Posted on May 23, 2011
When i try to suspend my pc, my motherboard gets f3 error and then restarts. The model is an old abit ab9 pro. I recently changed the ram and my os. The os runs perfectly.
have to select suspend mode s1 or s3 in BIOS power management to check the support mode, also check with hibernate, also need to free space in hard drive system partition for hibernating
Sep 11, 2016 | Abit AB9 Pro Motherboard
AB9 Pro motherboard
do this test this will tell you if your power supply is good or bad we will do the process of elimination ok.
How do I test if the power supply is bad?
Warning This test is for those with extensive electronics training. Do not try this if you do not have extensive electronics training. Make sure there is enough load connected to the power supply before testing ( at least motherboard and one hard drive)!
ATX power connector layout isshown above. 5VSB constantly provides 5V power to the connector through pin 9. If you have a voltmeter, while the power supply fan does not turn on, you could identify which pin is pin 9. Normally there is a clip on the connector between pin 15 and 16. If one can identify pin 14 (the only green wire goes to pin 14), this is the power-on pin. Onee can use a piece of wire to short pin 14 and 15 (or any other black wired ground pin). If you power supply has power connected to it and power switch on the power supply is on, the fan should be turning by now. Otherwise, your power supply may have problem.
Dec 27, 2007 | Abit AB9 Pro Motherboard
Few minute ago when i tried tunring on my pc it just stayed at the abit-intel loading screen thingy. (im entirely new too pcs fixing them that is ) it too about an hour or so befor it would tunr on normaly...
It could be the hard drive or any usb devices plugged in when booting up the computer. Try unplugging the hard drive and remove any USB devices and then try turning on the PC.
Dec 06, 2017 | Abit AB9 Pro Motherboard
I have an Abit BD7 motherboard with a phoenix bios and an intel 845 chipset. I am running Windows XP Professional on it. As of now, the system does not complete the POST bootup. It stops at A7 and...
try with reseting the cmos battery and clear the cmos also .try with other power supply also.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 23, 2010 | Abit BD7 Motherboard
Abit ab9 pro motherboard diagram
Abit Support > Abit AB9 Pro motherboard > Motherboard manual download page,
http://www.abit.com.tw/page/en/download/download_manual_detail.php?pFILE_TYPE=Manual&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AB9+Pro&pSOCKET_TYPE=LGA775
On this page left-click on the country nearest you
(Asis, Europe, US)
After you click a small window will come up -
Opening ab9_series.zip
Make sure there is a green dot in the circle to the left of Save File.
If not, left-click on the circle.
Now go below, and click on OK.
A small download window will appear on the left.
While it is downloading look at the heading.
It will show the percentage rate of downloading, and state where the file is going.
Example: 50% downloading - Downloads
I just downloaded the file. It is going to a sub-folder within the My Documents folder called Documents.
(WinXP: Start > My Documents > Downloads)
For me I will go to the My Documents folder, then double-click on Documents.
The file may go to the same place for you, or to your desktop screen.
This is a Zip file. You need a program to Un-zip the file, if you do not have one.
If you do not have a program I suggest you download 7-Zip for free.
(Zip files are used to send large files easily)
When you see the file name, Double-click right on it.
Click on Next, Next, and Finish.
You will now see a small window with the file name next to an Adobe PDF icon.
Double-click on it.
If you cannot download this file, let me know in a Comment as to what you wish to know about the motherboard, and I will post back in an additional comment.
Regards,
joecoolvette.
[ Thought I would include this also,
http://www.viperlair.com/reviews/cpu_mobo/abit/9xx/ab9pro/ ]
Oct 11, 2010 | Computers & Internet
I re installed windows XP and now my ethernet
You can find drivers for your motherboard at the following location:
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AB9+Pro&pSOCKET_TYPE=LGA775
Scroll down and look for: Realtek Gigabit Lan Driver
Aug 02, 2010 | Abit AB9 Pro Motherboard
Manual and Bios for Abit AB9 Pro Motherboard
Hello seany187,
What I'm doing since your system doesn't want to download from Abit, is creating a zip file with all the drives, manuals, utilities and bios updates for both XP, XP64, Vista, and Vista 64, since I don't what OS your on, and you will be able to download them from this private site HERE. And because the files are so large, I split them into, I'll post the second one as in a comment as soon as it's completely up on the site.. You shouldn't have any problems with these downloads, unless you have your IE settings to high.
Good Luck & don't forget to leave a rating based on my Solution.
Thanks Mark
Stay tuned for the second file!
Apr 06, 2009 | Abit AB9 Pro Motherboard
ABIT AB9 PRO WILL NOT POWER UP
Sounds like it's going to die or its gone faulty,
Might need to replace it or take it to a computer store and have them check it out.
Dec 28, 2008 | Abit AB9 Pro Motherboard
Have a Abit A17 mother board that posting a 25 or 5D error code
I picked this up from an abit forum, It appears that it is quite common, look here, http://forums.hexus.net/abit-care-hexus/104674-abit-ab9-pro-code-25-error.html
Dec 21, 2008 | Abit A17 Guru Motherboard
Badly flashed bios
i can fix that if only you are in my country(Philippines)
Sep 22, 2007 | Abit AB9 Pro Motherboard
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
